EAGLE User Support (English) 0V, GND, EARTH
  • Views 582 views
0V, GND, EARTH
mrmarple
mrmarple over 10 years ago
Probably not the correct forum to ask this question but the standard of the
contributors here suggests I'll get a good response, or at least provoke
some discussion.
Been around electronics a few years (think 12AX7/ECC83) and I never found a
satisfactory (to me) answer on what to do with 0 volts, chassis ground and
protective earth. The equipment I've worked on over the years have used
different strategies, some tie everything together, others attempt to keep
things separate, through in two and three pin plugs and it looks a bit of
an untidy mess.
I'm thinking horsepower BLDC motors, H-bridge drivers, controllers full of
CMOS and computer power supplies. I've had zaps and seen sparks when
plugging pieces of gear together which continue to function but I do wonder
what currents are flowing in a bit of 30AWG ribbon cable, and what's
happening to noise margins.
Keeping the +V sides of power supplies isolated with optocouplers is
straightforward but still puzzled about the 0V side. Tie the lot together
on the board, at the power supply, keep the protective earth separate?
Your thoughts.
  • gdstew
    gdstew over 10 years ago
    Just FYI, as far as I know every PC ever made connects the power supply ground (0V) and the chassis itself to the AC safety ground.
    This is not an ideal configuration as described in the first response.
    some discussion.
    an untidy mess.
    Your thoughts.
    This looks like two slightly separate questions, to me.
    Firstly, inside a specific box, should the ground rails all be common.
    Usually, the answer is "yes, but...", which is to say you often want to
    "star earth" things.
    Secondly, between separate boxes, such as a CD player and amplifier.
    Here, the problem you run into is earth loops. Where both boxes are
    independently grounded as well as connected together, there is a big
    loop of 0V wire, which acts as an inductive pickup. This plays merry
    hell with signals. So the way to avoid this is NOT to connect any of the
    equipment directly to earth, at least not via its mains cable, and have
    at most one ground connection for the circuitry.
    This being a potentially troublesome option, especially where the
    equipment is physically quite separate, the alternative is to use solely
    fully floating interfaces. An example of this would be the UTP Ethernet
    standard, which uses balanced lines over twisted pair with isolating
    transformers at each node.
    Personally, I tend to keep circuit ground separate from chassis ground
    but couple them with some limiting device (a capacitor or MOV) but
    others will almost certainly have better suggestions.
