EAGLE User Support (English) How to search in schema tic?
  • Replies 11 replies
  • Subscribers 180 subscribers
  • Views 970 views
Joop14
Joop14 over 9 years ago
I have a (system on a) module with 200 pins.
In the library, I divided these pins over 7 symbols in the device.
Those symbols are all in different schematic sheets. There are 15 sheets
so it's impossible to remember where is what.
Sometimes I need to find a certain pin of this module but I don't remember
on
which sheet it is.
My question is, is there a way to find out? I tried "run find" but it
doesn't offer what I'm looking for.
Thanks.
  • Joop14
    Joop14 over 9 years ago +1
    Done. I wrote myself an ulp that searches in the schematic for a certain pin. It requires two parameters, a part number (e.g. IC308) and a pad name. If the combination of the two parameters exists, it…
  • Joop14
    Well, that looks like the usual problem with Eagle.
    Every new version brakes one or more ulp's and, even after reporting,
    they keep on shipping them with newer versions.
    If you ask for a feature, they point you to a ulp.
    If you complain about a broken ulp, it has no priority because it's not
    part of the (core) Eagle program.
    Then there's another thing. I have difficulties reading other people's
    code.
    For me, it's usually faster to write something new from scratch instead of
    patching something
    existing.
    Thanks for helping.
