EAGLE User Support (English) Command Line Polygon
  • Replies 14 replies
  • Subscribers 179 subscribers
  • Views 2368 views
Hi all,
Is there a document somewhere that explains the command line options for
polygon?  Polygon has from, to, angle, width, layer, pour, name, etc.  How
can I do this from a command line?
Dave
    autodeskguest over 9 years ago in reply to autodeskguest +1
    Dave Wills schrieb: Paul Romanyszyn wrote on Wed, 14 September 2016 16:19 I would make a simple board with just a polygon, export as script then look at the contents. First thought was good idea. But you…
    Dave Wills wrote: Actually, the help menu doesn't. it does, at least for me 8-) I'd like to add a polygon in a script file where I do several post-route operations. The help menu doesn't help me figure…
    Tilmann Reh wrote on Wed, 14 September 2016 23:02
    then
    First thought was good idea.  But you can only export scripts from
    the
    library not the board.  Maybe I can't do this with a script.
    There is an ULP that exports a board as a script.
    However, it's no problem to just generate a script manually. First,
    set
    up the required parameters with the LAYER and CHANGE commands, then
    use
    the POLYGON command to draw the polygon:
    LAYER TOP;   (CHANGE LAYER would also work)
    CHANGE THERMALS on/off;
    CHANGE ORPHANS on/off;
    CHANGE ISOLATE xxx;
    CHANGE POUR solid/hatched;
    CHANGE RANK xxx;
    CHANGE SPACING xxx;
    POLYGON width 'name' (x y) (x y) (x y) (x y) ... (x y);
    If you don't draw only straight orthogonal lines, you might also use
    SET WIRE_BEND xxx;
    MITER xxx;
    before applying the POLYGON command.
    And yes, all that can be taken from the HELP POLYGON information (that
    also links to the CHANGE command, where the parameters for modifying
    polygons are clearly listed, and to SET and MITER).
    Tilmann
    Thanks Tilmann.  I did get partly through figuring this out last night, but
    then gave up.  Now that you've given me specifics, I will try again.
    Dave
    Lorenz wrote on Wed, 14 September 2016 23:26
    it does, at least for me 8)
    post-route
    operations.  The help menu doesn't help me figure out out to set
    the
    dimensions and location of the polygon,
    that at least is obvious from the help
    or how to set the remaining values
    I mentioned in my original post.
    if it's not a parameter of the polygon command itself, use the change
    command beforehand to set them up
    try this as an example:
          change layer top; change width 50mil; change rank 3; ch pour
    hatch; polygon foobar (0 0) (1 0) +180 (0 0);
    Lorenz
    Thanks Lorenz.  That helps too.  But you did get one thing wrong.  The
    reason it didn't help is because I am helpless.  image
    Dave
    post-route
    the
    Lorenz
    Dave
    Just to close this out, and to explain my confusion, I did not understand
    how the GUI operations translate into individual command lines.  I expected
    that I would be able to select all of the polygon options in the polygon
    command, not just the line width (and why is that different than name,
    layer, pour, etc?).  Once I saw what Tilmann posted, it made sense.
    Thanks to all.
    Dave
