EAGLE User Support (English) Group while using move tool
  • Subscribers 187 subscribers
  • Views 516 views
I'm sure a lot of us miss the common GUI function
"click-and-hold-LMB+hold-down-while-dragging" to do grouping, instead of
actually having to choose group tool first.
I'm hereby "thinking loud" if this would cause any conflict if added to
the move tool. Doing click LBM and hold while dragging doesnt really
make sense on the move tool. So why not use it to group?
Today the down-click starts the move operation. If it was moved to the
button release event (more common across different tools I guess), it
would enable Eagle to separate click+move from click only, and add this
long wanted auto-group + move function.
Also, script wise this could have been supported by a new "hold LMB" key
modifier, and it would not conflict with old functionality at all.
If the chosen modifier was '<' for "hold LBM", a command like "move (<0
0) (10 10) (R0 10);" would actually group the square, and move it up by
10 units.
Does anyone see any conflicts that I don't see?
    it would remove the click-drag-release method of moving objects/groups
    around.
    Why would it remove that? I didn't want it to replace the traditional
    move..
    you propose to use  left-mouse-botton-down+drag for grouping.
    In that case  mouse-downdragrelease  moves are no longer possible,
    only clickdragclick moves.
    Ah right, I never used drag + release myself.. I always click move
    click. Thats the scrip recipe too. Pity that you are so dependant on
    this, imo, special function.
    around.
    move..
    Lorenz
    10 units.
    around.
    And it would require - for consistency - to move the execution of all
    commands to the mouse release.
    At least the first of the two I would miss badly.
    move..
    10 units.
    around.
    Lorenz
