EAGLE User Support (English) Diff bus naming
  • Subscribers 189 subscribers
  • Views 1022 views
Diff bus naming
Currently, bus names may contain a single end bus of signal names ending
with the index#, like D[0..7],A[0..15]
However, diff signals needs to end with _P or _N for eagle to detect
them as diff, hence they can not be added to a bus using the index
range. D[0..7]_P,D[0..7]_N doesnt work. This means, diff buses must be
written with very long names.
I suggest that bus names should at support one of the following, ranging
from simple to complex effort:
1-Index in the middle of the name, such as D[0..7]_P,D[0..7]_N
2-D[0..7]_[PN] for even more compactness
3-Multiple indexes like D[A..C][0..7]_[PN], in good old regexp style.
Afaics, all of them should be compatible with existing names.
    autodeskguest over 10 years ago in reply to dukepro
    On 23.09.2016 17:58, Chuck Huber wrote:
    On 09/22/2016 08:52 AM, Morten Leikvoll wrote:
    On 22.09.2016 14:41, Chuck Huber wrote:
    ending with the index#, like D[0..7],A[0..15]
    ranging from simple to complex effort:
    One could use DP[0..7],DN[0..7], or D_P[0..7],D_N[0..7].
    I guess you mean that the diff definition has to change instead of bus
    naming definitions. DPn/DNn will not be routed as diff as it is now.
    Yes thats an option, to allow something after the P or N.. Or even
    make a general regexp for P/N pairs, like "^.*_[PN]$". I think it was
    suggested back at the days just before diff pair routing appeared.
    I see your point, multiple iterators in any position rather than a
    single iterator at the end.
    Hmmm...  So would you want the entire bus to route in the same manner as
    a single diff pair routes today (the follow-me routing feature), or
    would you prefer to route individual pairs separately?
    I kind of like this.  An entire bus, differential pairs or not, could be
    routed in this manner.
    I was more on schematic level, but you could suggest bus routing in a
    new thread. Sometimes I have missed it, even for single end buses. It
    would have to define a way to select multiple airwires for parallel routing.
  • dukepro
    dukepro over 10 years ago
    Later,
        - Chuck
  • rachaelp
    rachaelp over 10 years ago
    I'll support this suggestion too, I use busses a lot and diff pairs quite
    often, it would be very nice to be able to have a nice compact notation to
    specify the diff pairs within a bus. Happy with either option 1 or 2 for
    this. Option 3 looks like a great idea too, would have to have a think
    about the possibilities for how the extra flexibility could be used but in
    general I like all these ideas.
    Yes thats an option, to allow something after the P or N.. Or even make
    Odd that you mention regexps.  Every time I type in a bus name index I
    use a dash to specify a range, and have to go back and correct it to two
    dots.  Creatures of habit, I guess.
    Jorge, I'm in for this one.
    Regexp could be used more in Eagle. I use the strxstr() often in ULP's.
    I would like to see it used for show commands too, but thats for a
    different thread.
  • dukepro
