EAGLE User Support (English) How to remove unwanted d evices/packages/symbols?
  • Subscribers 187 subscribers
  • Views 308 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
I want a single library in my project folder containing the devices used in
that project.
That much I have done with the ex-lbrs.ulp. However, lets say I have used
just one resistor from the rcl library, then all of the devices, packages &
symbols have also come across into my project library!
How can I remove (or not add in the first place) the unwanted elements. Up
to now, I have had to laboriously right click on EACH item, select Remove
from the context menu and then confirm each deletion. Takes ages - and more
than once I have deleted the items I wanted because I had not been paying
attention!!
Regards, Martin
Ver 7.6.0 Linux (64bit)
