EAGLE User Support (English) Selecting objects in ULP
  • Subscribers 187 subscribers
  • Views 565 views
I'm updating a ULP that moves around text strings to simplify the process
of cleaning up the silkscreen and documentation layers after routing.
It has always bothered me that some objects, like text strings, can only be
identified by their coordinate in commands like MOVE.
First, is this really true?  If so, that seems dangerous since you're
relying on multiple objects not having the same coordinate.  To minimize
the chance of error, I make sure only one layer at a time is displayed.
Multiple text strings shouldn't be at the same place, but stuff happens,
even if just by accident.
If it is not possible to unambiguously identify specific text strings in
command like MOVE, ROTATE, and the like, then something like a unique "ID"
or "handle" would be useful in the UL_TEXT data structure.  The commands
would be able to accept that in place of the starting coordinate.  The
syntax around this doesn't need to be pretty, since it would only be
intended for writing by a ULP.
Any other suggestions how to perform actions on a particular text string by
writing a script from a ULP?
    autodeskguest over 10 years ago in reply to autodeskguest
    Morten Leikvoll wrote on Thu, 22 September 2016 10:27
    You can use the setgroup() function to group unique objects selected
    from different parameters in the ULP code, then moving the [single item
    in] group. But beware of the bugs. 7.6.4beta got the lastest ingroup bugs
    cleaned out.
    Interesting idea, but that only allows for creating a single group.  Since
    things can't actually be changed from inside a ULP, it has to write a
    script, which is executed automatically after the ULP.  However, these
    functions only seem to control the grouping during the ULP, so could create
    at most one group that a script can act on.  My ULP is for moving around
    all the NAME and DOCU text of all the devices in a board.
    bugs cleaned out.
    But I'm not sure if this will make your problems easier.
