EAGLE User Support (English) Text ALIGN attribute?
  • Views 1841 views
Eagle now supports anchoring text strings to the current point at the usual
nine positions (edges and middle in each dimension).  That's useful.  To do
that, you use CHANGE ALIGN to set the mode.  New text is then aligned to
the current point as specified.
However, I can't find any way to change the alignment of a existing text
string.  I searched in HELP for ALIGN, but relevant hits are only in CHANGE
and TEXT.  I tried CHANGE ALIGN, then clicking on a text string, but it
causes no change in the alignment.  How can I do this?  If not possible, is
this a bug, not implemented yet, something else?
    Am 22.09.2016 um 20:51 schrieb Olin Lathrop:
    rachaelp wrote on Thu, 22 September 2016 14:37
    but if say I wanted to change the alignment on another text object like
    a net label then it doesn't work for that because they don't have the
    alignment specified in that way. Maybe this is your issue?
    I only tried it in the board editor, on smashed text in the tNames, bNames,
    tDocu, and bDocu layers.
    It works for me, but devices must be smashed before in .sch or .brd
    (eagle 6.6.0)
    Joern Paschedag
    autodeskguest over 10 years ago in reply to rachaelp
    autodeskguest over 10 years ago in reply to autodeskguest
    rk wrote on Thu, 22 September 2016 14:25
    You can also change the alignment with CHANGE ALIGN and left-click the
    text's origin afterwards.
    That's exactly what I did, several times, and the text just sat there.  I
    clicked right on the little cross when zoomed in.  I tried it from a script
    too.
    I just tried it again in a new Eagle session, and now it works perfectly as
    expected.  Now I can't reproduce the erroneous behavior anymore.  Weird.
    Either I was consistently doing something wrong, or there is some subtle
    bug in Eagle where this doesn't work after just the right sequence of
    operations.  I was banging on it pretty heavily testing a ULP that writes a
    long script that does a whole bunch of text move and rotation operations.
    I'll assume it was some kind of cockpit error on my part unless I run into
    this again.
    If anyone notices something flaky in this area, please report it here.
  • rachaelp
    rachaelp over 10 years ago
    I agree with Rene, it seems to work for me too. That is, it works for text
    strings but if say I wanted to change the alignment on another text object
    like a net label then it doesn't work for that because they don't have the
    Best Regards,
    Rachael
    Hello Olin!
    CHANGE ALIGN works for me, quick test in the schematic:
    GRID inch;
    LAYER INFO;
    TEXT 'Test' (2 2);
    CHANGE ALIGN left-center (2 2);
    CHANGE ALIGN top-right (2 2);
    CHANGE ALIGN bottom-center (2 2);
    I know that you are a poweruser, so I am not quite sure if the answer is
    really that simple. Did I misunderstand something?
    Rene
