EAGLE User Support (English) Polygons not filling
  • Views 1028 views
I'm using Eagle 4.16 on Win7 x64.  I've created a number of polygons and
tried to expand them by adding additional polygons.  Even though I give
these additional polygons the same names as the ones they're expanding,
they don't fill when I run Ratsnest (see the two
http://i.imgur.com/Hu5XL0m.jpg, lower left of Q1 and C9).  What am I doing
wrong?
Also, how does the solder mask interact with polygons?  Some areas of them
I want covered, but others I want to be bare copper.  How do I specify what
I want?
Thanks?
  • dukepro
    dukepro over 10 years ago in reply to autodeskguest
    On 09/25/2016 10:45 AM, Karl Lautman wrote:
    Thanks, Rob. I thought naming a polygon the same as an existing net
    established the connection.  That's how it worked for the others in the
    image.  How else can a connection be established?
    Drop a via somewhere within the orphaned polygon, then change its name
    to that of the polygon.
    HTH,
        - Chuck
    I realize I can modify the existing polygons, but I thought creating new
    ones would be easier. When that didn't work I was curious why?
    wrong?
    Unless you have the "Orphans" setting on, a named polygon will only fill
    areas where it's got a connection to the net. Other polygon fills don't
    constitute a connection here, only real tracks or pads. In the case of
    your two small polygons, there is no such connection anywhere in the
    polygon, so they don't fill.
    By the way, what is the reason for creating these two extra polygons,
    when you could surely achieve the same by adding corners to the existing
    ones?
    I want?
    The solder mask has its own layers - tStop, bStop - which are "in
    negative", i.e. anything you draw in those layers removes solder mask.
    Pads and (some) vias automatically create an appropriate object in the
    stop layer. Polygons don't, but if you want to expose a bit of the
    copper all you need to do is draw a suitable shape in the tStop layer.
    I meant, "Thanks." not, "Thanks?"  It's a typo that looks kind of snarky.
