EAGLE User Support (English) Mirror components and tra ces in place
  • Views 807 views
Hi!
I need to "shift" the board side on a larger group of components and traces
on a design. If I group them and mirror, they will mirror on their group
axis rather than their own. The coordinates of components and wires need to
remain.
I have tried the mirror-board.ulp and
mirror-board-remirror-element-swap-layer.ulp, they do both mirror on group
axis. I guess a script that iterates through
all components and traces and mirror them would do the job (if I auto
replace layer="1" with layer="16" in the board files, it looks correct but
makes some inconsistency (because the components does not get mirrored).
Does anyone know a scrip for the job?
Best Regards
Ole.
    e14 Contributor over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote on Mon, 26 September 2016 23:19
    On 9/26/2016 10:39 AM, Ole Olesen wrote:
    Hi!
    and traces
    group
    wires need to
    remain.
    on group
    auto
    correct but
    mirrored).
    Best Regards
    Ole.
    Hi Ole,
    I hope you're doing well. A ulp like xfind would be able to accomplish
    what you are trying to do. It has a lot of options so you have to read
    up on it a bit, but you can download it from our website.
    https://cadsoft.io/resources/ulps/?query=xfind
    Best Regards,
    Jorge Garcia
    I made a little ULP (attached). I must sense the task in most cases, is a
    bit more complicated for a 100% bullit-prove solution, at least for some of
    the asymmetrical components, but at least it got me some of the way.
    Explanation:
    It loop through all element and mirror each one (at least at the end, when
    the concatenated string is executed). After that moves layer 1->15, 16->1
    and 15->16.
    Use and/or edit at your own risk!
    Best Regards
    Ole.
    Hi!
    and traces
    group
    wires need to
    remain.
    on group
    auto
    correct but
    mirrored).
    Best Regards
    Ole.
    Hi Ole,
    Best Regards,
    Jorge Garcia
    Explanation:
    and 15->16.
    Best Regards
    Ole.
    Hi!
    and traces
    group
    wires need to
    remain.
    on group
    auto
    correct but
    mirrored).
    Best Regards
    Ole.
    Hi Ole,
    Best Regards,
    Jorge Garcia
    Thank you Jorge!
    Will check it out image
    Best Regards
    Ole
    Hi!
    remain.
    Best Regards
    Ole.
    Hi Ole,
    Best Regards,
    Jorge Garcia
