EAGLE User Support (English) measuring min (clearance)   distance
  • Replies 8 replies
  • Views 2154 views
e14candies
e14candies over 10 years ago
Is there a function or way to display & highlight the minimum distance
between two objects(or traces.  Say you have a zig zag shaped polygon next
to a circular pad, or even two zig-zag traces in the vicinity of one
another.  Is there a way to display how close they come to one another?
    autodeskguest over 10 years ago in reply to autodeskguest
    Am 28.09.2016 um 08:43 schrieb Morten Leikvoll:
    On 27.09.2016 18:21, Jorge Garcia wrote:
    Off topic, but slightly related to the above + I'm touching things Eagle
    can't do, catching acid traps is another one. Examples shown here
    http://i.stack.imgur.com/rjEa5.png
    Hi Morten,
    That's a neat image, I've never heard the term acid traps before.
    Looking at the pictures I think I know what you mean, but if you could
    clarify a bit(more for my own education than anything) what an acid trap
    is that would be helpful.
    I figure that the clearance between same-name signals would be used to
    detect things like these.
    Best Regards,
    Jorge Garcia
    Acid traps are formations that don't easily let go of liquids
    because of capillary effects (see
    https://en.wikipedia.org/wiki/Capillary_action).
    In PCB manufacture terms, this liquid is acid used to etch the copper,
    or maybe even acid used to clean the exposed pads. If any of this acid
    is left during production, maybe even trapped under solder stop paint,
    imagine what it can do over time. Of course this has more effect on thin
    features. A thick feature probably has enough copper to neutralize the
    acid left, but still there might be moisture doing damage in
    the long term.
    Thanks Morten I have something learned image
    Joern Paschedag
    Hi Morten,
    Best Regards,
    Jorge Garcia
    the long term.
    Joern Paschedag
    Hi Morten,
    Best Regards,
    Jorge Garcia
    the long term.
    Hi Morten,
    Best Regards,
    Jorge Garcia
    the long term.
    Hi Morten,
    Best Regards,
    Jorge Garcia
    You can write an ulp for this if you really need it. You "just" need to
    wrire the functions to find distances from one object type to another,
    then loop through all or grouped objects.
    Once I made an ulp that could track down too small same-net clearances
    (sliver, shown here
    http://www.techdesignforums.com/practice/files/2012/10/tdf-oct12-mentor-pcb-fig4-lrg.jpg),
    and fill it with a wire. There may be pieces of that code that could be
    used. My large detailed filled polygons was making this a very time
    consuming process, but it would work nicely on grouped objects.
  • e14candies
    Thanks Jorge:
    Of course the measure tool could be used, but you'd maybe have to set/try a
    lot of endpoints, hoping to find the minimum, since the min could located
    "somewhere" along object A, going over to "somewhere" on object B.
    Similar functionality must already lie within Eagle, since it can check for
    clearance rule violations between objects.  I'd like to see this made part
    of the measuring tool to show what the actual min clearance IS, WHILE
    moving things around.  Maybe light up a dot at the point(s) that match to
    the min measured distance, to allow for scooting them.
    Or is there another way around this, that I'm missing?
    Hello Hoyt,
    There's nothing specifically tailored to that. You could achieve it
    using the dimension tool or other measurement methods such as setting a
    fine enough grid, place a relative origin and then read the coords off
    of the top.
    Best Regards,
    Jorge Garcia
