EAGLE User Support (English) toggle layer displaying
  • Subscribers 187 subscribers
  • Views 1506 views
I'm sure it must have been requested by someone before, but why don't we
have a toggle key for the display function yet? There is '-' to hide,
and afaics, the effort needed to introduce the toggle prefix can't cause
very much conflict, if any at all.
It would be very useful for those who want to make key aliases for
hiding/showing specific layers.
    autodeskguest over 10 years ago in reply to autodeskguest
    On 27.09.2016 20:51, warrenbrayshaw wrote:
    On 27/09/2016 11:46 p.m., Morten Leikvoll wrote:
    I'm pretty convinced I saw someone wanting to toggle each layer
    independantly, and I was thinking this could be useful for me right now.
    I want to toggle my signal layers by using CTRL-1..6, and I want them to
    toggle independantly.....
    Bill Westfield's toglays.ulp assigned to keys CTRL-1..6 will do exactly
    what you want.
    HTH
    Warren
    Ah, thanks, yes indeed. I didn't think of reading layer visibility
    status to change state (I should know better). This must be the reason
    why there is little whining about the topic.
    I think this isse is one of those smop issues that should just be fixed,
    but the existence of a perfect ulp always pushes it back in the queue.
    Unfortunately, this thread is probably not the last one about the topic image
    what you want.
    HTH
    Warren
    what you want.
    HTH
    Warren
    Hi Morten
    Toggle ULPs have been around for a long time but I don't recall a
    suggestion like yours.
    I think what you are saying is that you want to run a display
    command/script again and again. With each run you want specified layers
    to toggle between on and off.
    Can this not be done with two aliases and an assigned key to run
    'display last'.
    To achieve this I could see myself making a ULP that snapshots a
    starting display alias and within it you specify the layer you wish to
    toggle. An assigned key then runs the ULP and does the toggling.
    You could use a context menu to set up what you want to be the toggling
    layer by clicking on an object in that layer. The work flow would be
    great. You are working away and think, Hmmm, I would love to be able to
    toggle that layer. Right click a wire in that layer, run the context ULP
    and hey presto an assigned hot key toggles that layer on and off.
    Multiple layers toggling should be achievable to with a little expansion
    of the idea.
    Your need may be away from this scenario so apologies if it is.
    toggle independantly. Using display last will not work here, as I may
    for example search for the layer where my signal continues. Also context
    menu's for this isnt snappy enough, also you can not right click
    something on a hidden layer image
    Yes I could write an ULP that keeps last states in a file, but that will
    just be a workaround for a simple missing feature. The display command
    is there to change the view, not to configure something (like the layer
    command), so toggling a view must be a very natural thing to do.
    Hi Morten
    'display last'.
    of the idea.
    Regards
    Warren
