EAGLE User Support (English) Swap signal names
  • Subscribers 187 subscribers
  • Views 626 views
Swap signal names
When routing boards with MCUs often it's useful to change some signal
assignments to easily fan out the microcontroller.
Typically I have a short piece of net attached to the MCU symbol with a
label.
If I want to swap to signals I need to manually change the names of both.
Is there a way to swap signal names as we can with pins or gates?
    label.
    Hi Marco,
    At this point in time we don't have any mechanism for swapping the net
    names. I think it's a good idea though.
    I'll submit it as a suggestion though.
    Best Regards,
    Jorge Garcia
