EAGLE User Support (English) Sup and Pwr pins genera ting ERC warnings
  • Subscribers 187 subscribers
  • Views 576 views
I'm running Eagle 4.16 in Win7 x64.  I've created a number of parts and
assigned Pwr to their Vcc and GND pins.  In my schematic I name these VCC
and GND and then place +5V and GND symbols from the supply1 library and
name them VCC and GND (see attachment).  Nevertheless, when I run ERC I get
a warning like the following:
WARNING: Sheet 1/4: POWER Pin U$5 10_VCC connected to VCC
WARNING: Sheet 1/4: POWER Pin U$5 11_GND connected to GND
If I change the Pwr pins to Sup I get an overwritten warning instead, but
it's still a warning.  What am I doing wrong?
    autodeskguest over 10 years ago in reply to autodeskguest
    On 28/09/16 22:16, Karl Lautman wrote:
    You've included the pad number in the pins' names. Why?
    For such a big package it's easier for me to associate a pin on-screen with
    a pin on the datasheet if it's numbered on-screen.
    That's a very poor reason, and one I totally disagree with. The pin
    numbers of a TQFP64 (or bigger) are of absolutely no interest to me
    while I'm designing the schematic, because the data sheet refers to
    everything by its function / name throughout. Indeed, the last several
    big devices I've worked with all had datasheets that referred to a
    family of devices in packages from QFN36 to BGA144, with every single
    one using different pin numbering.
    More importantly, if I
    take the number away, the library editor won't let me give two pins the
    same name (e.g. VCC).
    Read the tutorial.
    If you want two pins with the same function, there is a proper way to
    name them. If you follow that convention, the one that Eagle is designed
    to work with, then you'll find it works a lot better.
    a pin on the datasheet if it's numbered on-screen.  More importantly, if I
    You've included the pad number in the pins' names. Why? Even if you
    don't care about the possibility that the device might come in different
    packages with different pin numbering (very common on devices that have
    pins called "PE6"), doing so is an unnecessary duplication. It also
    means your power pins are not called "VCC" and "GND" so you will get
    warnings about connecting them to a net with a different name.
    Fix your library parts (and while you're at it, assign an appropriate
    PREFIX to them) and you'll be able to lose those warnings.
