EAGLE User Support (English) DXF import to eagle 7
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 3390 views
Oppie
Oppie over 10 years ago
Trying to import a simple board for which I have a DXF file into eagle 7.
Tried Jorge's "import-dxf.ulp" (came with eagle7 ulp's) which generated only
a five line script and stopped. Don't know where I'm going wrong. The dxf
file opens fine with Draftsight.
I used to use Eagle Power Tools which had a dxf import that worked
splendidly. It's just not supported in eagle7.
The board is simple enough just to redraw but looking to the future, I would
like to get a working process.
Thank you - Oppie
  • rachaelp
    rachaelp over 10 years ago in reply to Oppie
    That's great, glad you now have it working :-)
  • rachaelp
    rachaelp over 10 years ago in reply to rachaelp
    rachaelp wrote:
    The scaling isn't right by default so you'll need to choose an appropriate scaling factor when you load it in.
    Ignore this last comment, just set the units to imperial and it's fine.
  • Oppie
    Oppie over 10 years ago in reply to Oppie
    DOH!  Yes, I thought I had ASCII but you were correct. This time I saved
    in
    autocad R12 ASCII format.
    Yes, that was it! Re-tried Faulk Stricker's Eagle PCB Power tools DXF to Scr
    converter and got a useable output. The script opened ok in Eagle7. Just
    cleaning it up now.
    Many thanks for the important pointer.
  • rachaelp
    Oppie wrote:
    DOH! Yes, I thought I had ASCII but you were correct. This time I saved in
    With your latest ASCII DXF file, using EAGLE 7.6.0 if I go File -> Import -> DXF... then select your file it does seem to import it although not all of it. Looking at it in eDrawings viewer there seems to be an entire document with sheet borders etc but this seems to just import the board part plus a few other bits in odd places.
  • Oppie
    Oppie over 10 years ago in reply to rachaelp
    "rachaelp" <noreply-391202@element14.com> wrote in message
    news:30459409.41475161103635.JavaMail.jive@e14-cr-vp-appj8-04.premierfarnell.net...
    Oppie wrote:
    DXF is attached. What a pain, since Eagle Power tools (for V5) imported
    DXFs
    perfectly.
    Hi Oppie,
    I just looked at your DXF and it's in AutoCAD binary DXF format which I
    suspect is the problem. Can you export from AutoCAD in an ASCII DXF
    format?
    Best Regards,
    Rachael
    https://community.element14.com/cfs-file/__key/communityserver-discussions-components-files/308/60_2D00_00209A1.dxf
  • rachaelp
    Oppie wrote:
    DXF is attached. What a pain, since Eagle Power tools (for V5) imported DXFs
    perfectly.
    Hi Oppie,
    I just looked at your DXF and it's in AutoCAD binary DXF format which I suspect is the problem. Can you export from AutoCAD in an ASCII DXF format?
    Best Regards,
    Rachael
  • Oppie
    Oppie over 10 years ago in reply to autodeskguest
    "warrenbrayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:nsi9tr$ov2$1@baboon.cadsoft.de...
    only a five line script and stopped. Don't know where I'm going wrong.
    The dxf file opens fine with Draftsight.
    would like to get a working process.
    Thank you - Oppie
    Hi
    You have some work to do.
    As I understand it, no ULP has ever worked with all dxf files.
    Historically, splines were the object that was not handled
    You need to determine which dxf entities are not supported by the ULP and
    then determine if your dxf file is free of those entities.
    From a quick look in the ULP, it appears to support the following
    entities.
    LINE,
    ARC,
    CIRCLE,
    POLYLINE,
    VERTEX,
    LWPOLYLINE
    So if you have others you can expect the ULP to ignore them or grind to a
    halt.
    Post your dxf here. Someone may be kind enough to inspect it. Going
    forward you will need to understand the dxf formatting so you match the
    file to an appropriate tool.
    HTH
    Warren
    perfectly.
    https://community.element14.com/cfs-file/__key/communityserver-discussions-components-files/308/60_2D00_00209A.dxf
    autodeskguest over 10 years ago in reply to autodeskguest
    As an after thought there have been discussions on taking the dxf >
    hpgl(inkscape)  >eagle route
    Search the forums for HPGL
    Try this link
    http://badcafe.co.uk/2011/03/20/dxf-hpgl-to-eagle-script-conversion/
    Warren
    Try this link
    Warren
    Thank you - Oppie
    Hi
    and then determine if your dxf file is free of those entities.
    From a quick look in the ULP, it appears to support the following entities.
    LINE,
    ARC,
    CIRCLE,
    POLYLINE,
    VERTEX,
    LWPOLYLINE
    a halt.
    HTH
    Warren
