EAGLE User Support (English) DXF import to eagle 7
  • Replies 11 replies
  • Subscribers 181 subscribers
  • Views 2872 views
Oppie
Oppie over 9 years ago
Trying to import a simple board for which I have a DXF file into eagle 7.
Tried Jorge's "import-dxf.ulp" (came with eagle7 ulp's) which generated only
a five line script and stopped. Don't know where I'm going wrong. The dxf
file opens fine with Draftsight.
I used to use Eagle Power Tools which had a dxf import that worked
splendidly. It's just not supported in eagle7.
The board is simple enough just to redraw but looking to the future, I would
like to get a working process.
Thank you - Oppie
  • Oppie
    Oppie over 9 years ago in reply to Oppie +1
    DOH! Yes, I thought I had ASCII but you were correct. This time I saved in autocad R12 ASCII format. Yes, that was it! Re-tried Faulk Stricker's Eagle PCB Power tools DXF to Scr converter and got a useable…
  • rachaelp
    rachaelp over 9 years ago in reply to Oppie
    That's great, glad you now have it working :-)
