EAGLE User Support (English) Polygon thermals on for t hroughole only
  • Views 354 views
Joop14
Joop14 over 10 years ago
Dear Cadsoft team,
Could you please add another polygon property?
Usually, I want thermals only for throughole components but not for SMD
pads.
This means that I have to draw separate polygons in the same layer, one
with thermals on and one with thermals off.
The reason is, that all SMD components are handled by a pick and place
machine, the throughole components
like pcb connecters and switches, are not. They are soldered by hand.
Thanks.
  • Joop14
    Joop14 over 10 years ago in reply to autodeskguest
    Morten Leikvoll wrote on Wed, 05 October 2016 14:16
    You do know the SMD's and PAD's in a package have a "thermal" flag that
    can be cleared (set by default)?
    Yes. But that's a weird solution because that way you need to create
    duplicate libraries,
    one with, and one without thermals. Not an elegant solution.
    The approach with polygons makes more sense imho.
    Thanks for trying to help.
    On 05.10.2016 10:32, Joop wrote:
    Dear Cadsoft team,
    pads.
    SMD's may often need thermals for service-friendliness or when wave
    soldered. They are not always reflow soldered.
