EAGLE User Support (English) Eagle 7.7.0 pinhead.lbr parts issue
  • Subscribers 187 subscribers
  • Views 246 views
prpplague
prpplague over 9 years ago
Greetings All,
to ensure all my designs that use standard eagle libraries remain consistent, i normally do a diff on those libraries when i upgrade to a new version of eagle. one of the issues that showed up is with the pinhead.lbr file. seems that the 2x22/90 and the 2x25/90 packages have some pins swapped. the pins that are swapped appear to be consistent with just the pins 40 to 50.
it is no longer clear as to where bugs/issues should be reported after the sale to autodesk... would be nice if the main website addressed that....
thanks
Dave
16621,16624c16328,16331
< <connect gate="A" pin="41" pad="41"/>
< <connect gate="A" pin="42" pad="42"/>
< <connect gate="A" pin="43" pad="43"/>
< <connect gate="A" pin="44" pad="44"/>
> <connect gate="A" pin="41" pad="42"/>
> <connect gate="A" pin="42" pad="41"/>
> <connect gate="A" pin="43" pad="44"/>
> <connect gate="A" pin="44" pad="43"/>
17054,17062c16761,16769
< <connect gate="A" pin="45" pad="45"/>
< <connect gate="A" pin="46" pad="46"/>
< <connect gate="A" pin="47" pad="47"/>
< <connect gate="A" pin="48" pad="48"/>
< <connect gate="A" pin="49" pad="49"/>
> <connect gate="A" pin="45" pad="46"/>
> <connect gate="A" pin="46" pad="45"/>
> <connect gate="A" pin="47" pad="48"/>
> <connect gate="A" pin="48" pad="47"/>
> <connect gate="A" pin="49" pad="50"/>
17064c16771
< <connect gate="A" pin="50" pad="50"/>
> <connect gate="A" pin="50" pad="49"/>
