EAGLE User Support (English) Rename existing floating wire segment in board
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 1671 views
If a signal segment has the signal name of an existing net present in
the schematic, Eagle refuses to rename it. You will get "please do this
in the schematic" message.
Now, if this segment was "floating", meaning it was not connected to any
of its target pins, or ending in airwires, why prevent this renaming? I
do support this "error" message when it is connected to one or more
target pins (although sometimes I would like to override it).
For now, I will write this function into my toolbox (ulp).
    On 01.11.2016 19:33, Jorge Garcia wrote:
    On 11/1/2016 11:43 AM, Justyn wrote:
    I would really like to see this feature too, and I think a dialog similar
    to what you describe would be a good way to do it.
    Hi Guys,
    I have just filed an enhancement report for this one. Sorry I took so long.
    Thanks Jorge.. I just found another issue that is closely related to
    this issue.
    The "rename oldname newname" command doesnt work for wires/nets in board
    editor.
    At least I would like this to be possible for nets not present in the
    schematics, cause now I get told to do it in the schematic... where it's
    not present.. Thats a bit funny..
    I want to use this to rename pasted wires to whatever they are connected
    to. As you know, pasted wires gets a new netname. Now I have to use
    "name newname (x y)" to get to it, and that is not so nice, cause other
    items may be at (x y) too, even at the same layer. Even hiding all the
    other layers doesnt get around all cases.
    Hi Guys,
    this issue.
    editor.
    Hi Guys,
    this issue.
    editor.
    autodeskguest over 9 years ago in reply to Justynb
    Hi Guys,
    Best Regards,
    Jorge Garcia
  • Justynb
    Justynb over 9 years ago in reply to autodeskguest
    On 27.10.2016 21:28, Jorge Garcia wrote:
    I'm listening intently to this thread.  I've had this need on numerous
    occasions.
    Jorge?  Care to chime in?
        - Chuck
    Hi All,
    I can't speak for the devs, but I think that they choose to err on the
    side of caution and just completely forbid net renaming on the board.
    In this particular case I'm having a hard time thinking of a good reason
    for this behaviour. I think the risk would be that if the floating
    segment has the same name as an existing net then renaming that segment
    would rename the whole net.
    The proper thing to do in this situation would be to have a dialog
    similar to the polygon where you would have the options:
    -rename only this segment
    -rename entire net
    Currently no such dialog is setup on the board side. I do think it is a
    reasonable request, a few things in EAGLE would have to change though.
    I see this as a valid concern. Especially when you edit a board alone.
    For sch+brd consistant projects, renaming a net should be a sch only
    feature, but I do see that would cause some inconsistancy and potential
    backward compatibility ulp issues.
    There are sexy ways around it, but that means you have to stop making
    command line unfriendly and forced requesters (who decided to use that
    in die hard command line based platform like Eagle anyway?). Do it, like
    suggested in older posts, with optional command line arguments instead,
    and you can keep all the default options legacy-like. This goes for all
    the existing requesters too. (Yes I know you can use set confirm, but
    that option is incomplete for a lot of the requests).
    autodeskguest over 9 years ago in reply to dukepro
    occasions.
        - Chuck
    Hi All,
    -rename entire net
    Best Regards,
    Jorge Garcia
  • dukepro
    dukepro over 9 years ago in reply to autodeskguest
    any
    if I understand you correctly, you want to 'reuse' an already routed
    track for a different net.
    After the rename the original net then would have an air wire instead
    of the track.
    Correct. I am doing large designs and sometimes I find a long wire
    segment already laid down is more suitable for a different signal, or
    I simply want to swap two wire segments because it will ease routing.
    occasions.
        - Chuck
    of the track.
    segment already laid down is more suitable for a different signal, or I
    of the track.
    Lorenz
