EAGLE User Support (English) Help with understanding l ayers, please.
  • Replies 10 replies
  • Views 828 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 9 years ago
I wish to work with a ST-Microlelectronics TDA7491HV. Which, if my
understanding is correct has a PowerSSO-36EPD or PSSO-36SD (or some other
combination of letters - depending on reference source!) footprint or
package.
As I have very little experience  in this skill area, I went looking for an
example on the web and found one at
http://www.diymodules.org/eagle-show-object?type=usr&id=101499&part=Audio-Power-amlifier+V.2.0.lbr&package=PSSO-36SD#preview
(an extract of this device is attached).
My question is this: What is the function of the rectangles on Layer 19
(Unrouted) sitting over the pads?
Is it likely to be a mistake and they should in fact be be on Layer 29
(tStop). However, if that is the case, the size is too small.
I'm confused...
Regards, Martin
Ver 7.6.0 Linux (64bit)
    On 29/10/16 08:16, Tilmann Reh wrote:
    Martin Rowe schrieb:
    I think it is safe to assume that: "There is no logical reason to PUT items
    on the Unrouted layer - The content of the unrouted layer is managed by the
    application".
    No - it is safe to assume that: You can /never/ trust any library from
    someone else. This includes those that come with EAGLE.
    In fairness, I think Martin's statement is probably a decent enough rule
    of thumb as well. But Tilmann's version is a useful adjunct to the more
    generic "never trust anything you find on the Internet".
    application".
    autodeskguest over 9 years ago in reply to mprowe@peritonlane.net
    Thank you both for your advice. I now have to confidence to go ahead and
    modify my copy of the downloaded library.
    application".
    Often it's even faster to create a needed part by yourself than trying
    to correct a downloaded one - which still includes some risk that you
    overlook something and later get in trouble.
    Tilmann
    application".
    Tilmann
  • mprowe@peritonlane.net
    mprowe@peritonlane.net over 9 years ago in reply to autodeskguest
    Hi Joern and David,
    application".
    Best regards, Martin
    Hi Joern and David,
    application".
    Am 28.10.2016 um 14:11 schrieb David Pollum:
    It looks like the author of the LBR made a mistake by putting marks on the
    pads in the Unrouted layer (#19) that should be in tDocu (#51). The copper
    planes also are not completely filled in under the chip because the author
    put circles in the Dimension layer (20), instead of tPlace (#21). As far as
    I can tell from the data sheet, these are molding marks and not holes in
    the chip.
    The library is not correct as David mentioned already.
    I don't know if I understand correctly your "trouble" with the unrouted
    "layers".
    This is just a "level" where yet unrouted  connections are shown.
    One must have the possibility to show or hide layers and that goes for
    unrouted as well.
    If  you have problems to see the unroutes wires you can easily change
    their color or turn off all other layers.
    Joern Paschedag
    the chip.
    Joern Paschedag wrote on Fri, 28 October 2016 08:16
    I don't see the stripes in the library. IMHO it would be better if you
    attach the board file here, so we can analyse it.
    Yes, of course, sorry. I have had to ZIP my sample board, it to get under
    the 50kb limit. hope that that does not cause yet more problems?
    My concern, I think, is my understanding of the function of the Unrouted
    Layer.
    What is the relationship between Layer 19 and the (incredibility difficult
    to find!) Unrouted Airwires that are presented following the Ratsnest
    function?
    Is the Unrouted Layer in some way related to the Auto-routing process?
    Does the Auto-router move Wires defined in the schematic, back and forth
    between coper layers and Unrouted Layers? And if so, what is the purpose
    (advantage?) of specifically placing items on the Unrouted layer?
    Sorry if the above sounds like the ramblings of the confused....
    Regards, Martin
    TDA7491HV-Breakout.brd.zip
    Am 27.10.2016 um 19:57 schrieb Martin Rowe:
    package.
    I'm confused...
    Regards, Martin
    Joern Paschedag
