EAGLE User Support (English) Eagle 7.7.0 and MCAD option
  • Subscribers 187 subscribers
  • Views 1319 views
Trying to visualize my board in ecad.io but the PCB is not showing up?
Only the parts?
https://gyazo.com/52e547bcf69d5ec79b25b4b1ea14d075
Glenn
    On 11/2/2016 12:20 PM, Jorge Garcia wrote:
    Yes my board outline is drawn on layer 20 in a library part.
    Anyway around this? I have 4 bus connectors and a number of standard
    outlines. It very easy to change things up with the buss's and outlines
    as library parts.
    Glenn
    Hello Glenn,
    I hope you're doing well. Could you send me the file for review?
    Best Regards,
    Jorge Garcia
    Hi Jorge, files sent.
    Glenn
    as library parts.
    Glenn
    Hello Glenn,
    Best Regards,
    Jorge Garcia
    as library parts.
    Glenn
    Hello Glenn,
    Best Regards,
    Jorge Garcia
    as library parts.
    Glenn
    Hello Glenn,
    Best Regards,
    Jorge Garcia
    On 10/31/2016 12:13 PM, Jorge Garcia wrote:
    Only the parts?
    Glenn
    Hello Glenn,
    I hope you're doing well. How is your outline defined? It should be
    drawn on layer 20 in EAGLE. If you have your outline defined as a
    library part then that might be part of the problem.
    Let me know.
    Best Regards,
    Jorge Garcia
    Hi Jorge, I am okay, thanks for asking. I hope this reply also finds you
    well.
    as library parts.
    Glenn
    Only the parts?
    Glenn
    Hello Glenn,
    Let me know.
    Best Regards,
    Jorge Garcia
