EAGLE User Support (English) back-annotate / re-annotate
  • Subscribers 187 subscribers
  • Views 2297 views
I have a customer request that a layout be re-annotated such that
smaller designators (R1, C1, D1, U1, etc) are in the upper left corner,
and larger designators are in the lower right.
1. Can Eagle do this in the board editor?
2. Can Eagle produce a text file listing the changes, i.e. R1 is renamed
to R12, C1 is renamed to C30, etc?
    On 11/1/2016 12:29 PM, stderr wrote:
    On 10/31/2016 5:25 PM, James Morrison wrote:
    stderr wrote on Mon, 31 October 2016 23:28
    renamed
    There is a ULP called "renumber" or similar that can do this.  However,
    EAGLE has what I call constant, or immediate, annotation.  What you do in
    one editor is automatically and immediately done in the other (PCB and
    SCH).  So to do this properly you need both SCH and BRD file then run the
    ULP in the PCB editor.  It will edit both the SCH and BRD at that same
    time.
    Cheers,
    James.
    Hi James,
    Thank-you! I took a look for a renumbering ulp, and I can find several
    that work on the schematic, but nothing for a layout. I searched on
    rename, renumber, annotate, back annotate, back, name, number... no
    results on most of them. Is it possibly under a different name?
    Cheers,
    Lawrence
    A crash course in ULP writing, and about a half day of fiddling, et
    voila! I can back annotate and spit out an OrCAD swap file. I can now
    back annotate the layout, schematic, and generate a matching bill of
    materials. It does not yet support a user menu, but that's tomorrow's
    problem.
    Thanks again,
    Lawrence
    renamed
    time.
    Cheers,
    James.
    Hi James,
    Cheers,
    Lawrence
    problem.
    Thanks again,
    Lawrence
    renamed
    time.
    Cheers,
    James.
    Hi James,
    Cheers,
    Lawrence
    problem.
    Thanks again,
    Lawrence
    renamed
    time.
    Cheers,
    James.
    Hi James,
    Cheers,
    Lawrence
    renamed
    time.
    Cheers,
    James.
    Order your EAGLE license from Stratford Digital at
    http://www.eaglelicenses.com
