EAGLE User Support (English) Interactive labels
  • Subscribers 187 subscribers
  • Views 633 views
Interactive labels
It would be cool if there are labels referencing a different sheet if I
could right click them and have a "show target" function e.g. it jumps
to the referenced sheet roughly focusing the referenced signal.
I'm just in the review of a 12 sheet large design and it would really
make the cross-checking easier...
Markus
    Awesome stuff!
    Thanks!
    Markus
    On 02.11.2016 20:04, Jorge Garcia wrote:
    I hope cadsoft reads this, maybe they can include some of these
    functions in a future version, and keep developing this context menu
    feature so this can look and function even more nice. Right now (7.7.0),
    even polygon functions pop up when selecting a wire, and there are
    missing objects that I would like to get my hands on through context
    menus.
    To install this ulp, type "run MLutils install" in the command line. To
    remove i, "run MLutils remove".
    Hi Morten,
    I'm insulted, you know I check these blogs almost daily. image
    This is a really cool ULP, I'm enjoying the functionality of it.
    Hopefully, once we get uploads up on the site again you can post it so
    that others can benefit from it. That is if you want to of course.
    Very cool.
    Let me know what you would like to see added to the context menu
    functionality so that I can prepare an ehancement report for it.
    Best Regards,
    Jorge Garcia
    Thanks Jorge, I find it very useful myself too, and I keep adding stuff
    to it. Yesterday, almost just after posting, I added a function that
    renames pasted wires to the overlapping wires' name. Some time ago I
    posted an suggestion for this to happen automatically when pasting
    stuff, but I use this ULP until Eagle gets there image
    [By all means, feel free to "steal" or make any of these ULP functions
    redundant by adding it to basic Eagle features.]
    When it comes to improving the context menu functionality, I have
    already posted a few suggestions, like "Adding stuff to group via
    context menu", "set context submenus and spacer", "context on pin/pad"
    and "SET CONTEXT context", but they all passed uncommented.
    Here is a summary out of the top of my head:
    In general, I would like as many object accessible as possible, and some
    new like "group", "all" and maybe be able to combine multiple selected
    objects into one set context command. For some objects, like polygons
    containing wire, objects like brd.polygon.wire would be nice, to catch
    polygon wires only. I have also suggested to add new items that is not
    in the traditional GUI too, like pins and pads. The most interesting is
    maybe the "group" object. See further down how I would like to see that
    happen.
    Also, the conflict explained with dual function of ingroup() would be
    really nice (or even necessary!) to resolve. The way its done now
    prevents context ULP's from adding stuff to the group. A new function
    incontext() to pass the context selected objects [instead of using
    ingroup()] would solve that, but it's already getting a bit late to
    change. I wouldn't mind the change to happen "over night", because it
    would open a lot of new functions to me. Maybe you can work out a
    backward compatible way of splitting context selected objects, and
    grouped objects,  like supporting a new "set ENHANCED_CONTEXT" feature
    that passes the object in incontext(), and keep the old as is.
    By doing this, you can also access grouped objects with a command like
    "set ENHANCED_CONTEXT brd.group 'command'". If there are items in the
    group, this needs to pop up in the context menu on any object. Note that
    the current grouped objects need to be passed to the incontext space, so
    that the function can keep adding objects to the ingroup space.
    There is also a problem adding context stuff across sch/brd/lib
    workspaces, like in my ULP, I couldn't get to the library polygon object
    during install. This should be handled globally, maybe with prefix on
    objects, like brd.wire and lib.wire.
    Related to this problem, as this ULP grows, and maybe other users add
    their context functions in ther own toolbox, I can see this is getting
    pretty awkward to handle all the "plugins". Maybe you can come up with a
    clever way to organize them? The keyword here may be "plugin" image
    Sorry for posting all this off topic, but I have to ride the wave now
    that I got your attention on the subject image
    missing objects that I would like to get my hands on through context menus.
    Hi Morten,
    Very cool.
    Best Regards,
    Jorge Garcia
    I have written this ULP toolbox that does something similar and other
    very useful functions for multi schematic and large designs. (To
    install, see bottom)
    This may do what you are after:Right click a part in sch/brd, and select
    locate in brd/sch from the context menu. It will switch focus between
    brd/sch for a selected part.
    Another useful function is the "navigate" that lists all connections for
    a specific net, and allows you to goto any of them. (I'm not happy with
    the list format atm, it looks a bit messy, so I may change it in a
    future version). It also does some ERC, but don't trust it blindly.
    Another cool feature I have added is the "group segment past/upto via"
    feature, that can group a full same-layer net segment by right clicking
    a wire of it, so you can easily change layer for it all. You have the
    choice to group upto or past vias.
    NOTE:This can also be done on buses, but unfortunately the context menu
    can not execute on groups, so you have to execute it manually.
    If you group at least one wire of each signal in a bus and type "run
    MLutils groupsignal", it will group all (same layer) of it, so you can
    easily change layer of the full bus.
    There are some other useful functions too, like polygon:move, ripup and
    viacount, layers:hide, display affected.
