EAGLE User Support (English) Net names suddenly appear ing on pads in ver 7.7
  • Subscribers 187 subscribers
  • Views 787 views
I just started the first layout since upgrading from version 7.6 to 7.7.
Now the net names appear on pads when previously they didn't.  See attached
screen shot snippet.
Needless to say, this is rather annoying.  I didn't ask for anything like
this when the new version was installed.  It just did it.  Now I have to
waste time while trying to do a board to figure out how to deal with this.
Argh!
Yo Cadsoft, STOP MAKING GRATUITOUS CHANGES SO THAT NEW VERSIONS DON'T WORK
LIKE THE PREVIOUS ONE.  It's good to introduce new features, but never
impose them on people without asking.  If you want new users to see a new
feature by default, make sure to have a mechanism that turns it off, and
then do so when upgrading from a previous version that doesn't include that
feature.
I can't rely on Eagle as a tool if new versions change my workflow and pop
new things in my face without my permission!
I might possibly use this new feature in some cases, but that should be for
me to decide when I'm ready, not when I need to get a board out.  In this
case, this feature doesn't tell me anything I can't get with Alt-V,N
quickly, but is in my face all the time when I don't care.  In the screen
shot example, it's cluttering up the component designators in the tDocu
layer.  I looked for some obvious new layer being displayed, but nothing
jumped out.
How do I turn off this feature to get back to the way it worked previously?
    CadSoft Support wrote on Mon, 07 November 2016 08:45
    you don't have to shout around here......
    I want you to understand how frustrating it is when Eagle suddenly does
    something different from before.  Don't underestimate how this pisses off
    existing users.
    Quote:
    I assume you know the settings in Options/Set. There you also find the
    new setting for
    Display Pad names
    Display Via Length
    and now new
    Display signal names
    That works, but that's just the clickety-click one-off way of fixing this.
    I want to update my eagle.scr file to document this, and so I don't have to
    do this separately on every machine I run Eagle on.
    I looked at HELP SET, but couldn't find this.  It's a long help page, and
    without reading every word, I didn't see it.  A find on "signal names"
    didn't bring up anything in the SET command page.  I also just discovered
    that you can't use regular find tools on the text in help pages.  Then I
    thought I'd print the help page to a PDF and search it that way, but there
    seems to be no way to print from the help viewer.  I had to copy the SET
    help page, then paste it into a text editor, to finally find
    Option.SignalNames.
    The help system could be more useful.  A set of PDF or HTML files would
    have more utility than help pages held captive in a help viewer with
    limited features.
    Anyway, for others, the way to turn this off is to with the command:
    set Option.SignalNames 0
    On 07.11.2016 14:45, Richard Hammerl wrote:
    Am 07.11.2016 um 14:40 schrieb Olin Lathrop:
    attached
    this.
    Argh!
    WORK
    that
    feature.
    pop
    be for
    jumped out.
    previously?
    Olin,
    new setting for
    Display Pad names
    Display Via Length
    and now new
    Here you can switchit on or off as you like.
    I can agree that the signal names on the pads are at times very
    disturbing. But signal names on wires are VERY useful. I'd like to
    switch off the names on pads, at least until it done in a better fashion
    (*), but afaics, there is no switch to turn off signal names on pads only.
    (*) see how horrible it becomes in the example posted in eagle.betatest
    with topic "Beta 7.6.3+:Showing signal names on pads"
    attached
    this.
    Argh!
    WORK
    that
    feature.
    pop
    be for
    jumped out.
    previously?
    Olin,
    new setting for
    Display Pad names
    Display Via Length
    and now new
    Argh!
    feature.
    jumped out.
    Olin,
    new setting for
    Display Pad names
    Display Via Length
    and now new
    Richard Hammerl
    Argh!
    feature.
    jumped out.
    Olin,
    new setting for
    Display Pad names
    Display Via Length
    and now new
    Richard Hammerl
