EAGLE User Support (English) Polygon bugs in ver 7.7
  • Subscribers 187 subscribers
  • Views 196 views
There is something messed up with polygons, at least in signal layers of a
board, in version 7.7.
I'm placing components on a 4 layer board.  I wanted a ground plane, so I
draw a polygon named "GND" over the whole board in layer 2, like I've done
many times before.  Everything looked OK, but the DRC coughed up a "width"
error at the bottom of the list.  This was shown to be only on the bottom
edge of the polygon, not the other three.  All four edges were draw exactly
on top of the dimension lines.
I checked, and polygon had a width of 0.008 inches, which should be fine.
I thought maybe I accidentally got something else in there while trying to
draw the polygon, so I went to delete it.  The polygon deleted as expected,
but the single blue line at the bottom of the board remained.  I displayed
only layer 2 and tried to delete it, but couldn't.  Grouping didn't work
either.  It beeped to indicate there was nothing in the group.  I did
RATSNEST and nothing changed.
Getting out of Eagle then back in made this strange remnant go away.  I
then carefully created the polygon again, this time typing coordinates to
make sure I didn't accidentally do something else with the mouse.  Same
thing.  The polygon showed up, but there was this strange remnant only at
the bottom edge that can be seen in layer 2, the DRC complains about
"width", but it otherwise doesn't seem to exist and can't be deleted.
I was curious if this had something to do with being coincident with the
dimension line.  I created a small polygon in layer 2 in the middle of the
board, and got the same DRC complaint about the bottom edge only.
But, there is now more strangeness.  No matter what I do, I can't get Eagle
to show this polygon filled.  And yes, I checked, "Ratsnest process
polygons" is turned on.
I deleted this polygon, got out of Eagle, got back in, and the remnant is
gone as before.
I created the layer 2 ground plane polygon again, and the remnant at the
bottom is back.  Getting out of and back into Eagle doesn't make it go
away.
Something broke from version 7.6 to 7.7.  Now what?
