EAGLE User Support (English) Polygon bugs in ver 7.7
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 1177 views
There is something messed up with polygons, at least in signal layers of a
board, in version 7.7.
I'm placing components on a 4 layer board.  I wanted a ground plane, so I
draw a polygon named "GND" over the whole board in layer 2, like I've done
many times before.  Everything looked OK, but the DRC coughed up a "width"
error at the bottom of the list.  This was shown to be only on the bottom
edge of the polygon, not the other three.  All four edges were draw exactly
on top of the dimension lines.
I checked, and polygon had a width of 0.008 inches, which should be fine.
I thought maybe I accidentally got something else in there while trying to
draw the polygon, so I went to delete it.  The polygon deleted as expected,
but the single blue line at the bottom of the board remained.  I displayed
only layer 2 and tried to delete it, but couldn't.  Grouping didn't work
either.  It beeped to indicate there was nothing in the group.  I did
RATSNEST and nothing changed.
Getting out of Eagle then back in made this strange remnant go away.  I
then carefully created the polygon again, this time typing coordinates to
make sure I didn't accidentally do something else with the mouse.  Same
thing.  The polygon showed up, but there was this strange remnant only at
the bottom edge that can be seen in layer 2, the DRC complains about
"width", but it otherwise doesn't seem to exist and can't be deleted.
I was curious if this had something to do with being coincident with the
dimension line.  I created a small polygon in layer 2 in the middle of the
board, and got the same DRC complaint about the bottom edge only.
But, there is now more strangeness.  No matter what I do, I can't get Eagle
to show this polygon filled.  And yes, I checked, "Ratsnest process
polygons" is turned on.
I deleted this polygon, got out of Eagle, got back in, and the remnant is
gone as before.
I created the layer 2 ground plane polygon again, and the remnant at the
bottom is back.  Getting out of and back into Eagle doesn't make it go
away.
Something broke from version 7.6 to 7.7.  Now what?
  • e14candies
    e14candies over 9 years ago in reply to autodeskguest
    Did you have netclasses defined for your GND signal? If that's the case
    that might explain why you got the width error.
    Is there a way to allow clicking on the error message to see the above
    info?  In some case (not all) Eagle could probably provide more details of
    the cause of any errors, or maybe even provide a tip (such as above),
    saving hours of frustration.
    Web access to CadSoft support forums at http:
    Thanks for your reply.  This turned out to be a bunch of interacting
    screw-ups on my end.
    Jorge Garcia wrote on Tue, 08 November 2016 12:35
    DRC errors involving polygons usually only grab one segment to draw the
    error polygon
    I didn't know that.  This may have been the first time I got a DRC error on
    a polygon.  This contributed to my not realizing there really was a DRC
    error.
    Yes, it turned out this is exactly what happened.  Portions of the
    schematic were copied from another project.  That, and what turned out to
    be a script that ran amok without other obvious symptoms, changed the
    netclass for GND to other than the default, something I usually don't do.
    This other netclass did indeed have a larger width than I used for the
    polygon.
    The rest of the problems followed from me not realizing this really was a
    genuine DRC error.
    Quote:
    The only way to get rid of DRC polygons is to either exit EAGLE like
    you
    did below, or open the errors dialog and click clear all.
    Yes, my mistake in not realizing this really was a genuine DRC error.
    Quote:
    Normally, polygons will only fill if there is a member of the net they
    can reach within it's boundaries. Try placing a GND via, does the
    polygon fill in now?
    I think I actually knew that at some point, but run into this so
    infrequently that I forgot about it.
    Quote:
    Both you and Chuck are experienced users so I would be surprised if you
    guys didn't already try what I mentioned above. With that said, I tried
    to reproduce the issue here and I can't find anything out of the
    ordinary.
    Sorry for the false alarm.  You get used to using a complex tool like Eagle
    in certain ways, and tend to forget details you aren't regularly exposed
    to.  I should have looked at the initial symptom more closely.
    What started me thinking down the wrong path was that the DRC error only
    showed on one of the polygon edges.  That immediately caused me to rule out
    a genuine width error, since that wouldn't apply to just one edge of the
    polygon.
    Again, sorry for the run-around.
    error polygon
    error.
    polygon.
    genuine DRC error.
    you
    ordinary.
    polygon.
  • dukepro
    dukepro over 9 years ago in reply to autodeskguest
    On 11/08/2016 12:35 PM, Jorge Garcia wrote:
    On 11/7/2016 1:15 PM, Olin Lathrop wrote:
    Hi Olin,
    so I
    done
    "width"
    bottom
    exactly
    the error polygon so this so far is OK.
    fine.
    case that might explain why you got the width error.
    Jorge,  try this from the control panel with all projects and editor
    windows closed.
    Here's what I did to duplicate Olin's find.
    From the control panel: File->New -> Board.
    From the Board Editor:  (Note that it's an empty board.  Nothing on
    layer 20.)
    • grid mil 10;
    • change width 8mil;
    • set wire_bend 0;
    • layer 1;
    • poly (10 10) (400 400) (10 10);
    • drc;
        I get the single error here along the bottom edge.
    • undo;
        (Gets rid of the polygon)
    • errors clear;
        (Gets rid of the DRC polygon.)
    • set wire_bend 4;
    • drc;
        I get the single error here along the left edge.
    Jorge,  You asked about the classes:
    • class
        0, default, 0, 0, 0mil
        (close the classes dialog)
    You also asked about the DRC params:
    • Clearance -> Everything is 8 mils
    • Sizes ->  Minimum Width is 10 mils
    • Layers -> (1*16)
        Note - two layer board.
    Hmmm... wait a minute... I just found it.  The minimum width is set to
    10 mils.  This means that the wire width for a polygon is checked
    against this parameter.
    I consider this closed and not a bug.
    trying to
    expected,
    displayed
    you did below, or open the errors dialog and click clear all.
    Not exactly true.  One can get rid of them using "errors clear;" in the
    command line.  But that's a bit off topic.
    of the
    Eagle
    Well, there was never a problem with the fill.
    you guys didn't already try what I mentioned above. With that said, I
    tried to reproduce the issue here and I can't find anything out of the
    ordinary.
    Best Regards,
    Jorge Garcia
    4745.att1.html.zip
    Hi Olin,
    The only way to get rid of DRC polygons is to either exit EAGLE like you
    to reproduce the issue here and I can't find anything out of the ordinary.
    Best Regards,
    Jorge Garcia
    Hi Olin,
    Best Regards,
    Jorge Garcia
    autodeskguest over 9 years ago in reply to dukepro
    Chuck Huber wrote on Tue, 08 November 2016 08:25
    errors whichever leg is drawn first
    That is consistent with what I saw.  It hadn't occurred to me this was
    related to the first wire of the polygon, but I did draw my polygons
    starting at lower left and proceeding counter-clockwise.
  • dukepro
    gone as before.
    away.
    Jorge,
    I've confirmed this as well.  I'm getting similar results as Olin on
    Linux / 7.7.0.
    I have found that the DRC error
    • has nothing to do with the dimension line (to which Olin eluded),
    • occurs whether the polygon is filled or not,
    • has nothing to do with the layer (I get errors on any layer - 1, 2,
        15, and 16), and
    • errors whichever leg is drawn first,
    More on the last bullet.  When drawing the polygon, there are several
    scenarios to explore.
    Case 1: "set wire_bend 0" (horizontal then vertical)
        a) Click bottom left corner, then top right corner, then bottom left
        again to close it, the bottom horizontal leg generates a width error.
        b) Click top left, then bottom right, then back to top left.  The
        top horizontal wire generates a width error.
    Case 2: "Set wire_bend 4"  (vertical then horizontal)
        a) Click bottom left, top right, then bottom left.  A DRC generates
        an error on the left wire.
        b) Click top right, then bottom left, then top right.  The right
        wire gets the error.
    I've tried wire bends with 45's and arcs, and it's always the first wire
    that generates the width error.
    However, running a DRC on older projects seems to be more hit-and-miss.
    Some polygons generate an error, while others don't.  It may be related
    to a wire breaching the side of the polygon where ratsnest would have to
    essentially cut the polygon wire and fill around the foreign signal -
    merely a hypothesis and not confirmed.
    HTH,
        - Chuck
    0363.att1.html.zip
  • dukepro
    gone as before.
    away.
    Jorge,
    Linux / 7.7.0.
        15, and 16), and
    HTH,
        - Chuck
    2860.att1.html.zip
