EAGLE User Support (English) Control Panel -> Show pr oject or file name
  • Views 453 views
Hi
Many times I have more then one project open at the time. It is real
difficult to find the right " Control Panel" to close. A lot of the time i
close the wrong one...
So please put the "filename" in the top of the "Control Panel". A simple
but powerful change.
  • dukepro
    dukepro over 9 years ago in reply to autodeskguest
    On 11/09/2016 12:17 PM, Jorge Garcia wrote:
    On 11/9/2016 11:20 AM, Flemming wrote:
    Hi
    time i
    Hello Flemming,
    I hope you're doing well. You should only have one control panel open
    at the time. Now we support a proper clipboard which allows multiple
    control panels however, it still not the best idea.
    I open two control panels quite often as well.  I just make sure that
    they open to different projects.
    It would also be nice if Eagle wouldn't complain when closing a project
    that has a read-only eagle.epf file.  Quite often a r/o project is
    opened for reference.  When closing the project (or quitting Eagle), I
    get one or two warnings.  The first might be about overwriting the
    project file with a newer version, and the second might state that it's
    write protected.  Of COURSE it is.  I don't want to write to it anyway.
    Just shut up and go away.
    Is there any setting that would prevent Eagle from complaining when it
    can't write to a project file?
        - Chuck
    I am old school, therefore i have used total-commander all my life. I open
    my file from there.
    Ex i open project 1 a schematic file, and project 2 another schematic file.
    Now there are 2x commander open. It is working nice, only thing is you easy
    get confused about witch commander there belong to a board or schematic
    file...
    Therefore my suggestion.
    my file from there.
    file...
    Hi
    Hello Flemming,
    I hope you're doing well. You should only have one control panel open at
    Thank you for your suggestion.
    Best Regards,
    Jorge Garcia
