EAGLE User Support (English) Impedance match and trace length
  • Subscribers 187 subscribers
  • Views 1755 views
Quick question:
Can the latest Eagle
1. Length (well, delay) match more than two signals simultaneously?
2. Create a controlled impedance trace?
I know that it can length match a pair if the signals are named
in a certain way, but I'm looking for a bit more than that.
Zoltán Kócsi
Bendor Research Pty. Ltd.
    I use this AR, it do it all and nice too!
    http://konekt.com
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    I would also appreciate some better length matching, since I'm going
    face DDR RAM routing sooner or later.
    I have no experience how this is done in other CAD packages, so I have
    no idea what would be the most user-friendly way of implementing this.
    If anyone could make suggestions on how to implement it in the group?
    Markus
    On 11/12/2016 7:22 AM, Zoltán Kócsi wrote:
    Quick question:
    Hello Zoltan,
    I hope you're doing well. The differential pair routing in EAGLE has not
    improved much since it was originally implemented. 1 is currently not
    possible and 2 is possible, possible but you need to calculate the width
    and lengths you need to achieve a given impedance. You'll also have to
    be careful with how you layout the trace to simplify your calculations.
    Best Regards,
    Jorge Garcia
    Quick question:
    Hello Zoltan,
    Best Regards,
    Jorge Garcia
