EAGLE User Support (English) Meander does not regard via length?
  • Subscribers 187 subscribers
  • Views 210 views
i am using the meander command, and i have the suspicion, that both meander
and run length do not regard the via length. For example, a layer change from
layer 1 to 16 and back, should add 2x1,6mm = 3,2mm in total. Eagle should
be able to add the via length, as the prepreg/core heighths are declared
in the drc settings.
Is there a way to switch this on?
Thanks in advance,
Steffen
