EAGLE User Support (English) eagle symbol problem, how to fix
  • Subscribers 190 subscribers
  • Views 927 views
  • frontpage
twilkers1976
twilkers1976 over 9 years ago
I'm trying to migrate an eagle symbol from 78xx (sparkfun lib) to LD1117 which has a different pinout.  I have relabeled the pins in the part, but the pcb symbol retains the old connections.  I'm very new to the symbol manipulation but have done several boards.  I tried to attach sch and brd files but this was disallowed.
in the device, there is no pin number associated with each pin, so the connect operation is a bit blind.
how do I fix this?
thanks,
tim
  • techsupport
    techsupport over 9 years ago in reply to twilkers1976
    HI,
    Not a bad option to build a component from scratch.  Remember you only need to edit the Pin names, then create a brand new device using the edited Symbol and exiting package.
    I hope this helps!!
    E
  • twilkers1976
    twilkers1976 over 9 years ago in reply to autodeskguest
    I went through that tutorial and just made one from scratch.  Thanks
    autodeskguest over 9 years ago in reply to twilkers1976
    Am 23.11.2016 um 20:18 schrieb tim wilkerson:
    I did forget that, but tried it now.  Closed and reopened eagle.  Same trouble.  Would you have a further suggestion?
    https://www.element14.com/community/message/210131
    Have you add a new technology to the device?
    so it may help to "change technology" in the schematic
    HTH
    Werner
  • omega-5
    omega-5 over 9 years ago in reply to twilkers1976
    There is a good
    "Tutorial for Creating Device Models in CAE Tool CadSoft EAGLE"
    you can download it from
    https://cadsoft.io/resources/documentation/1012211595/
    Freundliche Grüße / Kind regards
    Friedrich
    ... benutzen Sie nntp://news.cadsoft.de und einen
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • twilkers1976
    tim wilkerson wrote on Wed, 23 November 2016 09:31
    I'm guessing you forgot to do a LIBRARY > UPDATE_ALL in the schematic.
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
