EAGLE User Support (English) New element in library don't show
  • Replies 12 replies
  • Subscribers 190 subscribers
  • Views 4996 views
zoks
zoks over 9 years ago
I created a new lbr file from here
https://github.com/robertstarr/lbr_user/blob/master/switch-ck.lbr
I placed this lbr file i Eagle lbr folder, and in control panel I can see elements in a library.
But when I open schematic, and click "Add" i cant find it in a list
I performed "Library=>Use" and "Library=>Update All" but still I can't see it in "Add" list
  • zoks
    zoks over 9 years ago in reply to techsupport
    OK, problem is solved, when I read your post it give me idea to open library in control panel (this part was working) and
    than I just save it (I change nothing, only save).
    And now it is working, library appeared in Add list (after Library => Use)
    Obviously some glitch happened when I create first time this lbr file.
    Thanks everybody
  • techsupport
    techsupport over 9 years ago
    On 11/24/2016 09:18 AM, Zoran Radicanin wrote:
    https://www.element14.com/community/message/210153
    Make sure you can open the library an view the content, its possible you
    have bad data in the file and EAGLE doesn't recognize it.
    You need to be using EAGLE v6 or later.
    HTH,
    Ed
    On 24.11.2016 15:18, Zoran Radicanin wrote:
    I dont know if this helps, but I have seen eagle having problems to
    update if there is a library with the same name in some path,
    even if the other library is not in use.
  • zoks
    zoks over 9 years ago in reply to gpsmikey
    I don't know how to check this what you pointing. My Eagle is installed on D disk (D:/program files/Eagle 7.7.0 , library and project file is placed inside eagle folder
      (library is $EAGLEDIR\lbr) . And I see that tree in win explorer, I don't know what else to check.
    BTW , I reinstalled complete EAGLE (with antivirus disabled), but nothing changed.
    I try to import other library (file is inside folder "Zoran_custom" visible on images above), there are some elements that I created long time ago, and this
    library appear normally in Add list.
    So obviously problem is with exactly this library "switch-ck.lbr", and problem is present only on my laptop at Work, at home I don't have such problem with this same file.
    Very strange
  • gpsmikey
    gpsmikey over 9 years ago
    Are you sure you put the library where you think you did?  Win7 and it's
    ever handy "virtual store" where you put something one place, windows
    actually puts it somewhere else in the "virtual store" under your account
    and then another process not running as you can't find it.  It may be a
    protection thing biting you if you are trying to put the libraries in the
    main path instead of a path under your account.  See
    http://www.sevenforums.com/general-discussion/222389-what-virtual-store-folder.html
    (I have been bitten by this one several times in the past).  I like
    Unix/Linux - it will tell you "no" if you don't have permission.  Windows
    just sweeps it under the carpet and does not tell you it has done that. image
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • zoks
    zoks over 9 years ago in reply to autodeskguest
    Hm, problem that I described above is happening on my laptop at work, I just try same thing on my home laptop and here everything is normal, library is visible in Add list.
    Maybe I have some issue with antivirus on work laptop, I will check in 2 days since I will not be in office tomorrow.
    autodeskguest over 9 years ago in reply to zoks
    On 30/11/2016 1:37 a.m., Zoran Radicanin wrote:
    OK, Thanks, I correct it, now path leads to 7.7.0 , but unfortunately  still, no switch-ck.lbr in Add list.
    Again in schematic I performed Library => Use => Eagle 7.7.0/lbr/Github/switch-ck.lbr and than checked list in Add, it is still missing in list.
    Can you or somebody try to check this lbr file, maybe something wrong with it?
    Hi
    I do not have a problem with that library file. (Using Win7)
    Maybe, recheck your directory paths in Control Panel > Options>
    Directories...
    HTH
    Warren
  • zoks
    On 29/11/2016 9:16 p.m., Zoran Radicanin wrote:
    I do in a same way (Library => Use , than library appear in Add list), and I newer had a problem before, but now it is not working.
    BTW, I forger to mention, Eagle version 7.7.0
    I'm not sure that I properly done file creation from this github link above, since that "download" is not working correctly (I get unusable HTML document),
    I click on RAW, Select all (Ctrl + A), Copy, and Paste in empty notepad document, which I named switch-ck.lbr . Placed under Eagle LBR folder (...lbr/Github/switch-ck.lbr).
    In past I made lbr. files from that source several times in that way and I don't remember that I had such problems.
    Like I said, I control panel I can see this library (see screenshoot)
    But not in a list
    https://www.element14.com/community/message/210329
    Hi
    The answer is in the images
    The top one shows you looking at a directory for Eagle 7.7 and yet the
    image for the ADD shows you are looking at Eagle 6.3
    It's likely that the eagle.epf file for the project is still listing the
    6.3 files.
    With the project open
    Right click on the Libraries folder and select
    Use None
    Use All
    That should fix your issue
    HTH
    Warren
  • zoks
    zoks over 9 years ago in reply to dougw
    But not in a list
