EAGLE User Support (English) New element in library don't show
  • Replies 12 replies
  • Subscribers 182 subscribers
  • Views 4560 views
zoks
zoks over 9 years ago
I created a new lbr file from here
https://github.com/robertstarr/lbr_user/blob/master/switch-ck.lbr
I placed this lbr file i Eagle lbr folder, and in control panel I can see elements in a library.
But when I open schematic, and click "Add" i cant find it in a list
I performed "Library=>Use" and "Library=>Update All" but still I can't see it in "Add" list
    autodeskguest over 9 years ago in reply to zoks +1
    On 29/11/2016 9:16 p.m., Zoran Radicanin wrote: I do in a same way (Library => Use , than library appear in Add list), and I newer had a problem before, but now it is not working. BTW, I forger to mention…
  • zoks
    zoks over 9 years ago in reply to autodeskguest +1
    Hm, problem that I described above is happening on my laptop at work, I just try same thing on my home laptop and here everything is normal, library is visible in Add list. Maybe I have some issue with…
  • zoks
    zoks over 9 years ago in reply to techsupport +1
    OK, problem is solved, when I read your post it give me idea to open library in control panel (this part was working) and than I just save it (I change nothing, only save). And now it is working, library…
  • techsupport
    techsupport over 9 years ago
    On 11/24/2016 09:18 AM, Zoran Radicanin wrote:
    https://www.element14.com/community/message/210153
    Make sure you can open the library an view the content, its possible you
    have bad data in the file and EAGLE doesn't recognize it.
    You need to be using EAGLE v6 or later.
    HTH,
    Ed
  • zoks
    And now it is working, library appeared in Add list (after Library => Use)
    Obviously some glitch happened when I create first time this lbr file.
    Thanks everybody
