EAGLE User Support (English) Origin layer at schematic editor
  • Subscribers 187 subscribers
  • Views 623 views
In the schematics, I'd like to see the origin cross on a separate layer,
so we can hide it the same way the green pads/vias are hidden on board
when selecting background color for them.
This should go for all object including text.
    On 30.11.2016 22:38, Olin Lathrop wrote:
    Morten Leikvoll wrote on Wed, 30 November 2016 03:33
    layer,
    Then you wouldn't be able to select or move the objects.
    There are two outcomes of having them on a separate layer:
    1-If the COLOR of the origin layer is set to background, you will still
    be able to move it, but won't see where the origin is. In general I dont
    care where it is, a long as my symbol is where I want it. This may be a
    problem for weird symbols where the origin is far off, but if you need
    to find it, you get the option to make it visble again by setting it to
    a normal color.
    2-if origin layer is turned off, you will not be able to move them. Like
    in board editor, this option is maybe not very useful, but rather a side
    effect.
    When this is said, It is of course also possible for Cadsoft to ignore
    the origin all together and rather generate a virtual handle near the
    "center of gravity", or just respond to any of the symbols visible
    parts. The user doesnt need/want to care about the origin, they only
    care about wysiwyg.
    layer,
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
