EAGLE User Support (English) Getting rid of silkscrean on bPlace layer
  • Subscribers 190 subscribers
  • Views 1403 views
nmbr6
nmbr6 over 9 years ago
Hi all,
I'm working on a board very loosely based on Adafruit's NeoPixel FeatherWing - 4x8 RGB LED (https://www.adafruit.com/products/2945
Problem is - Adafruit's logo is imprinted in the bPlace layer and I just can't get rid of it, no matter what I do.
Any ideas how to do this??
Thanks!
    autodeskguest over 9 years ago in reply to rachaelp
    On 29/12/16 12:04, rachaelp wrote:
    It's because you need bOrigins and tOrigins to be able to select anything in either the bottom or top side layers
    ... for an appropriate value of "anything". Things you draw directly on
    the board, such as "wires" or "circles", can be selected in the layer
    they're on. Objects from a library are placed by origin.
  • rachaelp
    rachaelp over 9 years ago in reply to nmbr6
    You're welcome :-) It's because you need bOrigins and tOrigins to be able to select anything in either the bottom or top side layers respectively. Turn off the origins and you can't select anything.
    Best Regards,
    Rachael
  • nmbr6
    nmbr6 over 9 years ago in reply to rachaelp
    Hiding in bOrigins! How on earth did you figure that out??
    Thank you!
  • rachaelp
    I just downloaded it from the link and I can delete the Adafruit logo fine. You need to turn on bPlace AND bOrigins and then you will see the origin for the logo. You can then go into delete mode and select and delete the logo as you would expect.
    Best Regards,
    Rachael
  • nmbr6
    nmbr6 over 9 years ago in reply to jameslittlefield
    Definatly in the bPlace layer... I only had this one on.
    You can download the original design here and see for yourself:
    https://github.com/adafruit/Adafruit-NeoPixel-FeatherWing-PCB
    I got the same issue with some other Adafruit boards I was looking in though.
  • jameslittlefield
    jameslittlefield over 9 years ago
    Couple of things you can check...
    a) Is the bOrigins layer visible/turned on?   If not you won't be able to
    select stuff on the bottom layer.
    b) Are you sure that the logo is really on the bPlace layer?   Try turning
    off all layers and then turn them back one one by one until you find the
    layer that makes the logo visible.   Depending on the tools used to import
    the bitmap logo it may be appearing on a different layer than you expect.
    jl
    http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
