EAGLE User Support (English) MCAD and arc's not rendering board outlines correctly
  • Subscribers 187 subscribers
  • Views 742 views
Hi Jorge, did you get an email from me with a sample design which shows
MCAD can't render board outlines with arc's in them properly?
Glenn
    On 1/14/2017 12:13 PM, Glenn Jones wrote:
    Hi Jorge,
    I received your reply by email.
    So I have board outlines in one library and different bus types in a
    second library to logically separate them.
    Then depending on the board being designed I mix and match them.
    They are defined in different packages as that provides the most
    flexible use of these objects and greatly simplify's  things for me.
    Would some kind of ulp help to merge the two together after being added
    to the drawing?
    Hi Glenn,
    Unfortunately, we don't have anything for it at this time. Its a pretty
    niche situation so I don't for see us writing anything for it.
    One thing you could try to make it easier on yourself, is to change the
    layer of the outlines in the library to something other then dimension.
    When you bring the parts into your design use the
    copy-wire-to-any-layer.ulp to copy the outlines from your library layer
    to layer 20 Dimension. This will put the outlines together on your board
    as a single outline and should make ecad.io happy.
    Try that and let me know how it goes.
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    to the drawing?
    Hi Glenn,
    Best Regards,
    Jorge Garcia
    Hi Jorge,
    to the drawing?
    Glenn
    On 1/11/2017 11:52 AM, Jorge Garcia wrote:
    On 1/10/2017 4:41 PM, Glenn Jones wrote:
    Ping to catch Jorge's attention?
    Glenn
    Hi Glenn,
    I have it, I'm still catching up on my backlog I was out of the office
    for almost 2 weeks. I'm almost caught up though so you should have a
    response before the end of the day.
    Best Regards,
    Jorge Garcia
    Glenn
    Hi Glenn,
    Best Regards,
    Jorge Garcia
    Thanks - hope your time off was relaxing image
    Glenn
    Hi Glenn,
    Best Regards,
    Jorge Garcia
    Glenn
