EAGLE User Support (English) ULP: When iterating through parts, can I get to nets?
  • Views 991 views
bbartley
bbartley over 9 years ago
I'm creating a ULP to export a netlist but for my purposes it would be a lot more direct to iterate through the parts, and export those one by one, specifying what net is on what pin. But the data structures visible via the ULP interface seem to only make it possible to see what parts are on a net (rather than what nets are attached to a part). Am I missing something, or am I going to have to build up a whole counterpart to the existing data structures to do what I need?
Brad
  • bbartley
    bbartley over 9 years ago in reply to autodeskguest
    Ahh, the extended functionality of sort() is what I was missing. So I *do* have to build up a counterpart data structure (the parallel string arrays), but sort() makes it easy to flip that around from net-centric to part-centric.
    Thanks very much!
  • bbartley
    Export -> Pinlist comes pretty close to generating something that I could post-process into what I need. But I also need to get to some attributes. (If pinlist export were implemented as a ULP, I would've been able to modify it trivially.)
    I had completely overlooked the pinlist possibility though, so thanks for the suggestion!
    Brad
    Isn't this just a matter of sorting? From allnets(), loop through
    pinrefs and store the net.name and part.name in two string arrays. Then
    use sort().
    I was a bit quick. You may want to add the pin.name to that list so it
    ends up like: part.name,pin.name,net.name
    Brad
    use sort().
    Brad
    https://www.element14.com/community/message/212804
    Does File > Export > Pinlist not give you what you want without writing
    a ulp?
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
