EAGLE User Support (English) EAGLE v8.0 Slice Command   Doesn't Work on Group or Fr om Command Line
  • Subscribers 187 subscribers
  • Views 902 views
This new slice command doesn't seem to work on grouped traces.  I selected
multiple traces with the group command and then applied the slice command
to the group, but nothing happened.
Also, I can't invoke the slice command from the command line.  I can start
it but I can't feed it the parameters to actually do the command.  So it
required mouse use to function.
While I can appreciate new implicit commands give the user some flexibility
by selecting the function first and then the object (like the slice command
currently works), I strongly feel that the original mode of EAGLE functions
should be maintained as well:  select the function, then select the object
or group of objects to apply the function to.  And all of that should be
completely functional from the command line.
In the many, many schematics and boards I've done this mode of operation
(select function first then apply to object or group) has proven to be the
most efficient method. And if I have to start to remember which commands
work in which mode then that's going to start to become more and more
confusing as new commands are added.
The beauty of EAGLE commands is the orthogonality and that everything can
be scripted by using the command line.
James.
http://www.stratforddigital.ca
http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
    Eric has it mostly right.  I understand how the command works as is.  I had
    two points:
    1)  How the command works is NOT orthogonal with how every other command
    in EAGLE works.  Pick function, apply to object or group with the group
    having been defined by the preceeding group command.  If I try to do that
    it doesn't work and it should.  You've provided a different method which is
    fine, but it should work in the old way too to keep orthoganlity.
    The reason for doing this is learning curve.  If commands use different
    modes of operation then I also have to remember which command works in
    which mode.  This is bad for usability.  Orthogonality is good.  If you
    want to have a special, optimized mode (like group now does) that is great
    and power-users like me will use it.  But things should also always work
    in the EAGLE way to help new users.
    2)  As the splice command is implemented you can't use it in a script.  If
    this precedent is followed then scripting loses most of its power as new,
    powerful commands are added but not usable in scripts.
    It seems like some good functionality was added but by product managers who
    didn't fully understand the actual power in why EAGLE was implemented in
    the way it was.
    Cheers,
    James
    Eric Stevens wrote on Thu, 19 January 2017 18:41
    I believe James' question boils down to why can't I execute 'SLICE (x1
    y1) (x2 y2) '?
    Eric
    On 01/19/2017 01:34 PM, Jorge Garcia wrote:
    selected
    command
    can start
    So it
    flexibility
    command
    functions
    object
    should be
    operation
    be the
    commands
    more
    everything can
    James.
    Hi James,
    I think you've misunderstood how the command works. You don't have
    to select the traces in order to slice them.
    Here's the basic workflow:
    1. Click on the Slice icon.
    2. Now you are going to define a slice line that runs through the
    traces you wish to slice. Left click the first point
    of the line.
    3. You'll notice that now you have line going from that point to
    your mouse cursor. Left-click to define the second point.
    4. Voila, you'll notice that the traces have been sliced following
    the line you defined.
    On the command line you can enter specific points for the slicing
    line as well as how wide the gap should be.
    Best Regards,
    Jorge Garcia
    I believe James' question boils down to why can't I execute 'SLICE (x1 y1) (x2 y2) '?
    Eric
    James.
    Hi James,
    I think you've misunderstood how the command works. You don't have to select the traces in order to slice them.
    2. Now you are going to define a slice line that runs through the traces you wish to slice. Left click the first point
    of the line.
    3. You'll notice that now you have line going from that point to your mouse cursor. Left-click to define the second point.
    4. Voila, you'll notice that the traces have been sliced following the line you defined.
    On the command line you can enter specific points for the slicing line as well as how wide the gap should be.
    Best Regards,
    Jorge Garcia
    James.
    Hi James,
    you wish to slice. Left click the first point of the line.
    line you defined.
    Best Regards,
    Jorge Garcia
