EAGLE User Support (English) V8 Overlapping parts
  • Replies 10 replies
  • Views 1140 views
With Eagle V7 and below one could select a part and then use the mouse
or pop up menu to select the next overlapping part.
I am not seeing that option any longer? There is no Next on the menu for
example.
Glenn
  • rachaelp
    rachaelp over 9 years ago in reply to rachaelp
    Hi Jorge,
    I just tried this on my MacBook Pro and it's working fine on the track pad now..... The only thing is I did have EAGLE crash and quit itself while testing this out. I have tried to replicate the crash but as yet I can't get it to crash again. I will continue to see if I can replicate this issue. I'll also try on the iMac later and see if the original issue can be replicated for a video.
    Best Regards,
    Rachael
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Hi Jorge,
    I'll try and get a small video of the issue done this evening. I'll email a
    link over to you.
    Many thanks,
    Rachael
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    autodeskguest over 9 years ago in reply to rachaelp
    On 1/21/2017 4:21 AM, rachaelp wrote:
    Hi Jorge,
    I previously tried it on the MacBook Pro and I was using the trackpad. I have just loaded it up on my iMac which uses a proper mouse and it still doesn't work reliably for me. Unfortunately this makes selecting the right thing in an area with dense routing quite problematic. If I do as Shabaz suggested above and turn off the "Group command default on" setting then it's back to being usable with the right click scrolling through the selection options. In principal the new group select function is really cool and testing it out I liked it, but as it breaks other fundamental functionality for me when it is enabled it will unfortunately have to be turned off on my machines so I won't benefit from it.
    Best Regards,
    Rachael
    https://www.element14.com/community/message/213721
    Hi Rachael,
    I hope you're doing well. This needs to be investigated further, when
    you have a chance could you make a video showing me what you see. I'm up
    to my neck in forums I need to answer.
    Or if you want e-mail me directly. If this is real I want to see if I
    can make the developers aware of it in time to get a fix in the next update.
    Thanks.
    Best Regards,
    Jorge Garcia
    Autodesk Support
  • rachaelp
    Hi Jorge,
    Best Regards,
    Rachael
    On 1/20/2017 2:47 PM, Rachael wrote:
    Jorge Garcia wrote on Fri, 20 January 2017 19:19
    If you are using the new group selection mode, the cycle selection is
    done by holding down alt and then left-clicking mutliple times to cycle
    through the nearby items. The last one selected gets added to the group.
    Hi Jorge,
    Thanks for the advice, I've just tried it but unfortunately it's not
    reliable for me. Sometimes it works and sometimes not. This is on my
    MacBook. I've not tried on any other OS.
    Best Regards,
    Rachael
    Hi Rachael,
    Under the new group mode, the catch factor radius is much smaller so you
    really have to be directly on top of the two intersecting objects for
    the alt+left-click to work.
    If you are using a trackpad it's very likely the gestures won't work.
    Are you using a mouse?
    Best Regards,
    Jorge Garcia
  • rachaelp
    Hi Jorge,
    Best Regards,
    Rachael
    shabaz over 9 years ago in reply to autodeskguest
    Hi Jorge,
    Ah, I see. I went to Options->Set->Misc and unchecked "Group command default on" and now the behaviour is close to the
    older EAGLE versions (except Esc needs to be pressed twice to exit out of the group selection white wire).
    Mabe as a future idea it could be possible to swap it around, so that the select works like before, unless Alt is pressed, in which case
    it does the polygon group select thing, because although the polygon select is nice, it is more rare to want to do that.
    Anyway, it is good that by unchecking I'm almost close to the original method.
    I'll spend some time reading about the features, so that I'm better prepared. I just loaded an old design into v8, to check it would
    load fine, and still need to experiment.
    Thanks for investigating!
    autodeskguest over 9 years ago in reply to shabaz
    On 1/20/2017 6:55 AM, shabaz wrote:
    I think it must be unintentional too, the help file in v8 still states that the feature exists.
    https://www.element14.com/community/message/213574
    Hi Guys,
    Let me know if that works for you.
    Best Regards,
    Jorge Garcia
    shabaz over 9 years ago in reply to rachaelp
  • rachaelp
    I've just tested out and can confirm that I no longer see the "next" option
    so if I have things which are close to each other and the wrong thing
    selects I don't seem to be able to get to the next selection option.... Is
    this an unforeseen consequence of the new selection mechanism? I'm sure
    removal of this is unintentional....
