EAGLE User Support (English) V8: Where are the classic icons?
  • Subscribers 187 subscribers
  • Views 906 views
I cannot find the option anymore to switch back to the classic icon set.
As the new icons are still horrible, I would prefer to have the old ones
back.
Markus
    2017-01-23 09:38 keltezéssel, Richard Hammerl írta:
    On 23.01.2017 08:46, Rob Pearce wrote:
    On 22/01/17 23:57, warrenbrayshaw wrote:
    I too prefer the classic icons to the current batch of 'modernised'
    ones. Horrible they are.
    This is a statement that I could make about EVERY piece of software I
    ever use. There is a trend in "modern" GUI design to replace perfectly
    functional, clear, distinctive and legible icons with... things that
    some graphic artist feels are more "stylish" but which have nowhere near
    enough contrast to be visible, nor enough clarity to mean anything. When
    will these so-called experts learn that a GUI is meant to be USED, not
    admired for its artistic value.
    EAGLE V8 comes with the new icon set and it has been reworked compared
    to V7 in terms of readability. The new icons are scalable what the old
    were not.
    If you do not like them, switch all the toolbars off and use the
    commandline.  image
    Or let's vectorize the old icons and call it a day.
    were not.
    commandline.  image
    Richard Hammerl -- EAGLE Support
    On 23/01/2017 9:27 a.m., René König wrote:
    Hi!
    Am 22.01.2017 um 21:13 schrieb Markus Rudolf:
    back.
    Bad news:
    http://forums.autodesk.com/t5/eagle-forum/eagle-8-0-0-icons/td-p/6818269
    Rene
    A modern icon set would be fine by me but the first attempt by Cadsoft
    missed the mark. Basically they are to chunky and upset the balance of
    the UI. Additionally, some of the symbology was wrong like the stop icon
    which is not stop in my part of the world but rather do not enter or
    even one way.
    I have not viewed v8 but did expect the Autodesk 'look' to be applied.
    Hence these icons would have been replaced with a more pleasant set.
    When the new icons first arrived, you could create your own svg icons
    and apply them. Can some one tell me if this is still possible.
    Regards
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    On 22.01.2017 21:27, René König wrote:
    Bad news:
    That is not going to be on the pro side of the pro/con for an update.
    After playing around with V8 a bit, except for the slice command I don't
    see anything worth even a new revision number. This "design block
    feature" is the hierarchical design they promised to be in V7 already...
    Markus
    Hi!
    back.
    Bad news:
    Rene
