EAGLE User Support (English) PCB Routing Tool Enhance ment:  Setting Active Routing   Layers Dynamically
  • Views 378 views
I often find it would be nice to tell EAGLE which layers I intend to route
on in the near future.  Two cases:
First Case:  4-Layer Board
Most 4-layer boards have a similar stackup to:
Top
INNER1 - GND layer
INNER2 - POWER layer
Bottom
In this case, I am very rarely going to route to the inner two layers.  But
with EAGLE I always get a popup menu on layer switch and there is an
additional step of choosing the destination layer.  There is no ambiguity
here in this design--I will almost always go from routing on top to bottom
(or bottom to top).  So the extra step of choosing layer is irrelevant and
inefficient.
If I could just mark Top and Bottom as active routing layers then there
would be no need for the secondary selection.
Second Case: Multi-Layer Board
In dense board layout, you want to minimize the number of vias as they take
up a lot of space.  So with good planning, you can often find yourself in a
situation where you're routing a bus across a board and you are only going
to use 2 layers to do it.  If I could set my active routing layers to the
two in question, then again I save the extra step of selecting destination
layer for each via.
When that bus is complete I could set the active routing layers to all the
signal layers again.
Cheers,
James.
http://www.stratforddigital.ca
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Hi James,
    I'll second this suggestion, although it would also help if I were able to
    more easily switch between layers on my Mac as it doesn't have a middle
    button so can't scroll through the layers with just the mouse. At least
    with v8 they have added the keyboard accelerators space and shift+space to
    move between layers and also backspace to undo the last left click! I
    didn't know about this until I was testing out as I was working out my
    reply to this and found it in the manual! I won't mention the importance of
    providing release notes again.....
    I agree with Morten from his reply to your earlier version of this
    suggestion. I think the place to correctly specify this would be within the
    net class setup but I think generally the setup and usage of net classes
    needs a lot of work and expansion of functionality so this is something
    that could form part of that.
    However, being able to manually specify this would also be beneficial as
    often people work with just the default net class for everything and never
    bother with them (probably because they are of very limited use at the
    moment) so I think this is a really good idea which would definitely help
    out when routing.
    Best Regards,
    Rachael
    Here's the same suggestion I had back from 2011:
    http://www.eaglecentral.ca/index.php/m/136334/fbf4112cf39cd7a05430861a7c835887/?srch=middle#msg_136334
