EAGLE User Support (English) Composite part with "real istic" pads
  • Replies 13 replies
  • Subscribers 190 subscribers
  • Views 1738 views
mrmarple
mrmarple over 9 years ago
I've created a component, a DC-DC convertor.
An outline with a few circles and rectangles in layer 21 make a reasonable
looking package, adding four round corner pads results in a usable part.
However the part has four rectangular corner pads, not round pads and being
a bit anal about it I've been attempting to create rectangular pads but no
success so far.
Tried overlaying rectangles in the pad layer, overlaying rectangles in top
and bottom layers, creating/overlaying SMD pads top and bottom. Each
attempt has a problem, DRC layer abuse, tracks routed through the pads,
auto-router ignoring the pads even though air-wires show connections.
I'm sure there will be a way to doit, but not found it yet.
Thanks in advance! Ken.
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • mrmarple
    mrmarple over 9 years ago in reply to Joop14
    I noticed that when I was drawing rectangles in 1 and 16 and expecting them
    to be recognised as pads, thanks anyway Joop.
    Joop_ wrote on Sat, 28 January 2017 15:02
    Pay attention that, with arbitrary pad shapes, the solder stop and
    cream layers are not automatically
    adjusted like as the standard pad shapes. You have to draw them
    yourself.
    Why Cadsoft did this, I don't know. It looks clumsy and is prone to
    error.
  • mrmarple
    yourself.
    error.
  • Joop14
    Joop14 over 9 years ago
    Pay attention that, with arbitrary pad shapes, the solder stop and cream
    adjusted like as the standard pad shapes. You have to draw them yourself.
    Why Cadsoft did this, I don't know. It looks clumsy and is prone to error.
  • mrmarple
    mrmarple over 9 years ago in reply to mrmarple
    At last, DRC error free large pads with PTH that auto-route correctly.
    Thanks, Ken.
  • mrmarple
    mrmarple over 9 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Sat, 28 January 2017 01:31
    The 'correct' way to do this would be in the package creating
    'Arbitrary
    pad shapes'.
    In the package editor place your PTH pads, round or square.
    Over them on the the layers of interest., top and/or bottom, draw a
    polygon that represents the rectangular pad. You will need to take into
    account the wire width. You will need to manually address solder mask
    and such.
    See the manual in your documentation folder. The chapter on Arbitrary
    Pad Shapes is what you should read.
    Thanks Warren, I'll try try the recommended method.
    However it did occur to me that the pad that appears on the package is what
    ends up on the board, where a round pad is perfectly acceptable. What I am
    trying to achieve is just for cosmetic effect, four pad coloured rectangles
    at the package corners.
    Ken
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    'Arbitrary pad shapes'.
    Yep, do what Warren suggests! For some reason I was thinking that was only
    for SMT pads but clearly that wasn't correct and it should work for regular
    PTH pads too. So basically if you do as I suggest but in the library itself
    (you wont need to name the polygons) then it should be correct for every
    time you place the part.
    Best Regards,
    Rachael
    autodeskguest over 9 years ago in reply to mrmarple
    On 28/01/2017 8:25 a.m., ken wrote:
    rachaelp wrote on Fri, 27 January 2017 18:50
    Ah right I understand now! I'm not sure that it's possible to create
    rectangular PT holes. Would you accept a solution which meant you
    extended the pads to rectangles from squares in the layout?
    Really ? I thought it was just my lack of an imaginative solution (or
    limited ability).
    Quote:
    You could have a standard square PTH in the library part and then in
    the board draw rectangles top and bottom of the board the shape of the
    pad on you want for each PTH. Then name each rectangle with the net name
    relating to the pad.
    Then draw stop mask rectangles on the tStop and bStop layers to ensure
    the mask doesn't cover the area of your extended pads.
    What I have currently is small square PTH pads overlaid with rectangles in
    the pad layer and t/b/v restricts which seem to be required to stop
    unrelated tracks being routed through the pads, maybe because 'Layer Abuse'
    DRC errors allow the auto-router to do odd things.
    I think your solution is a better way to go but as the sun is about to rise
    here I'll try it tomorrow.
    Thanks, Ken
    Hi Ken
    The 'correct' way to do this would be in the package creating 'Arbitrary
    pad shapes'.
    and such.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
  • mrmarple
    mrmarple over 9 years ago in reply to rachaelp
    limited ability).
    Thanks, Ken
  • rachaelp
    rachaelp over 9 years ago in reply to mrmarple
    rectangular PT holes. Would you accept a solution which meant you extended
    You could have a standard square PTH in the library part and then in the
    board draw rectangles top and bottom of the board the shape of the pad on
    you want for each PTH. Then name each rectangle with the net name relating
    to the pad.
    Then draw stop mask rectangles on the tStop and bStop layers to ensure the
    Best Regards,
    Rachael
  • mrmarple
    Sorry Warren, not ignoring you, was composing reply and missed your reply.
    I think I covered what you suggest in my reply.
    I want rectangular (not square) normal pads that result in a PTH when the
    component is used.
    Ken
