EAGLE User Support (English) Composite part with "real istic" pads
  • Replies 13 replies
  • Subscribers 190 subscribers
  • Views 1689 views
mrmarple
mrmarple over 9 years ago
I've created a component, a DC-DC convertor.
An outline with a few circles and rectangles in layer 21 make a reasonable
looking package, adding four round corner pads results in a usable part.
However the part has four rectangular corner pads, not round pads and being
a bit anal about it I've been attempting to create rectangular pads but no
success so far.
Tried overlaying rectangles in the pad layer, overlaying rectangles in top
and bottom layers, creating/overlaying SMD pads top and bottom. Each
attempt has a problem, DRC layer abuse, tracks routed through the pads,
auto-router ignoring the pads even though air-wires show connections.
I'm sure there will be a way to doit, but not found it yet.
Thanks in advance! Ken.
EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
  • mrmarple
    mrmarple over 9 years ago in reply to rachaelp
    rachaelp wrote on Fri, 27 January 2017 17:48
    Maybe I am missing what you mean so possibly a picture of what you are
    getting and what you want would help. However, if I understand correctly
    can you not just go to the properties dialog for each pad (Right Click
    Context Menu -> Properties) and then change the roundness setting to sat
    50%? I just tried that one one of my parts and I got rectangular pads
    with rounded corners.
    No, I'm the one missing something.
    Easy way is to use non-SMD square pads but they are not rectangular and not
    that I want.
    Your 50% roundness taken to 0% applied to SMD pads certainly gives correct
    appearance but SND pads don't have holes and don't give a PTH in the main
    board.
    I suppose what i'm asking is how do I create rectangular normal pads with
    holes?
    Attached is a pic of the component.
    success so far.
    Hi Ken
    You can change the shape of a pad.
    In the package editor display the properties of the pad and change the
    'Shape' to square.
    Or .. In the package editor click 'Change > Shape > Square and then
    click on each of the 4 pads.
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
  • rachaelp
    rachaelp over 9 years ago
    FeralCl wrote on Fri, 27 January 2017 17:37
    reasonable looking package, adding four round corner pads results in a
    usable part.
    being a bit anal about it I've been attempting to create rectangular pads
    but no success so far.
    top and bottom layers, creating/overlaying SMD pads top and bottom. Each
    Hi Ken,
    Context Menu -> Properties) and then change the roundness setting to say
    50%? I just tried that one one of my parts and I got rectangular pads with
    rounded corners.
    Best Regards,
    Rachael
