EAGLE User Support (English) ARDUINO MEGA2560 NOT AUTOROUTING ON EAGLE
  • Subscribers 189 subscribers
  • Views 724 views
  • eagle cad
  • arduino mega 2560
  • cad_eagle
praneeth997
praneeth997 over 9 years ago
Hi there
I am facing a problem with the eagle library that I have downloaded from this website
the arduino mega2560 with the PCB footprint is not auto routing
The element14 Arduino CadSoft Library (Rev C)
  • mvackel
    mvackel over 9 years ago in reply to rachaelp
    do you know a lib that can add an Arduino as part on another board? Thanks!
  • rachaelp
    rachaelp over 9 years ago
    It's because you have used an Arduino library that is intended for creating shields to place the connectors for fitting an Arduino as a component to the board. The shield versions have a board outline for the shield on the dimension layer and when placing these on another board you will make EAGLE think it's a cut out area and it therefore can't route to it. You need to use an Arduino library library intended for adding an Arduino as a part on another board instead.
    Best Regards,
    Rachael
