EAGLE User Support (English) Best way to design a stacked PCBs circuits
  • Subscribers 187 subscribers
  • Views 190 views
I'm going to develop a circuit that will be composed of two stacked PCB.
Several connectors will provide connections between the two layers.
I wonder which is the best approach in EAGLE to do this.
The simplest way is of course to make different projects, one for each PCB.
The mains drawbacks are:
  • lot of signals are the same (those that go with the connectors) so any
changes to their names or net classes must be repeated in the second
project as well
  • the same applies for the layout: the positions of mounting holes or
any milling layer must be kept in sync with the PCBs
  • last but not least, in the lower PCB I have several tall components.
In the higher PCB I need to provide slots for them. Doing that in
different project is a pain because I need to write down the position of
each one and move the related slots every time I change their placement
I hope there is a better way to design stacked PCB circuits!
Marco
