EAGLE User Support (English) signal line connected to a ground
  • Subscribers 187 subscribers
  • Views 202 views
I've gotten myself into a bit of a bind and need to sort this out.
I have a connector for a module and I wanted to name the connector pins
the module's signal names. Where I ran into problems is when a signal
line was to be grounded. Schematic shows the pin with module's name as
desired and also shows a connection to ground. Trouble is that a ground
was never routed to the board.
Any ideas what went wrong and how I can prevent this from happening on
the next release?
TIA Oppie
