EAGLE User Support (English) signal line connected to a ground
  • Views 893 views
I've gotten myself into a bit of a bind and need to sort this out.
I have a connector for a module and I wanted to name the connector pins
the module's signal names. Where I ran into problems is when a signal
line was to be grounded. Schematic shows the pin with module's name as
desired and also shows a connection to ground. Trouble is that a ground
was never routed to the board.
Any ideas what went wrong and how I can prevent this from happening on
the next release?
TIA Oppie
    autodeskguest over 9 years ago in reply to rachaelp
    On 2/28/2017 2:23 AM, Rachael wrote:
    Hi Oppie,
    In addition to checking what Jorge has suggested I wonder if you connected
    the module up to ground symbols, initially correctly connecting to the
    globally named ground net, and then you renamed the nets from that to the
    module name and therefore disconnected them from ground.
    For global nets like power and ground I would either add separate text to
    annotate the connections at the connector or just accept that the names
    match the global nets on the board rather than trying to make them conform
    to the modules pin names.
    Best Regards,
    Rachael
    I didn't want to take the global name because it was important to me to
    recognize this pin as an I/O that was grounded as opposed to ground.
    Probably the most straightforward way then is to use a zero ohm resistor
    or a solder jumper.
    Was juggling a large number of signals and missed fixing that along with
    another engineer that helped with the review... Oh, well, boo boo
    happens. Probably needed to re-spin the board before the production
    release anyway. Sadly, I am getting very good at putting jumpers on
    0.5mm pitch devices.
    Oppie
    Hi Oppie,
    Best Regards,
    Rachael
    or a solder jumper.
    Oppie
    Hi Oppie,
    Best Regards,
    Rachael
    or a solder jumper.
    Oppie
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Hi Oppie,
    Best Regards,
    Rachael
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    the next release?
    TIA Oppie
    Hi Oppie,
    I'm sorry to hear that. The first thing that comes to my mind is that
    you may have hidden airwires.
    You can check by clicking RATSNEST and then looking at the bottom left
    of your screen. If you see the word "hidden" anywhere there, than that
    would explain the unrouted airwires. Type RATSNEST * followed by the
    enter key to reveal all of the airwires.
    The other possibility is that the airwire was not properly defined in
    the first place. In your schematic use the show command and click on the
    nets that never routed both pins and the net wire itself should
    highlight. You can also try moving the part, if the nets follow then it
    is properly connected otherwise that's your issue.
    Best Regards,
    Jorge Garcia
    Autodesk Support
    We have a new forum here <http://forums.autodesk.com>
