EAGLE User Support (English) Black window is not dark "theme"
  • Views 2980 views
I'm using the black background of windows in EAGLE (and in other
applications) to reduce the eye's fatigue. But the dialog windows still
have a white background... in the night this is quite annoying because
you continue to switch between black and white (i.e. the Add window).
Is there a way to set a dark "theme" to all EAGLE windows?
I know I can set globally this in Windows, but it's not reliable because
many applications are not designed for dark themes and they look horrible...
    Il 22/03/2017 01:28, Warren Brayshaw ha scritto:
    Not within Eagle but there appears you can apply a theme to a single
    application.
    This linux example may help.
    http://askubuntu.com/questions/78088/can-i-apply-a-different-gtk3-theme-from-the-main-one-to-an-individual-applicatio
    I'm afraid this wouldn't work under Windows.
    application.
  • COMPACT
    COMPACT over 9 years ago
    Hopefully Autodesk may consider this as a future feature through its main user interface dialog box.
    application.
    HTH
    Warren
    EAGLE support forums at http://www.eaglecentral.ca :: Where the EAGLE community meets.
    application.
    HTH
    Warren
