EAGLE User Support (English) DipTrace
  • Replies 18 replies
  • Subscribers 191 subscribers
  • Views 2477 views
DipTrace
Does anyone have some experience with DipTrace?
Now that Eagle became a subscription service, from our point of
view it's dead. While the last version we have is still running fine,
obviously we'd like to explore other moderately priced commercial
quality options for the future. We don't do Windows and don't want to
run Wine either which severely limits our choices.
One possibility would be DipTrace, which on the surface seems to do
everything that Eagle can do and it's pricetag is at the same league.
So I just wonder whether someone had some experience with it and could
compare it to Eagle, pros/cons, better at this, worse at that style?
Zoltan
Zoltán Kócsi
Bendor Research Pty. Ltd.
  • COMPACT
    COMPACT over 9 years ago in reply to autodeskguest
    I find it interesting that you work width.
    Do you also work with height and length?
    You can go use vintage apps like Protel AutoTrax or even P-CAD.
    On Mon, 3 Apr 2017 12:21:33 +0200
    Morten Leikvoll <mleikvol@yahoo.nospam> wrote:
    On 31.03.2017 16:18, Zoltán Kócsi wrote:
    Of those I really miss the DOS OrCAD's schematics editor, the most
    useful(!) feature rich schematics entry I've ever worked width. Then
    they moved to Windows and replaced the useful features with useless
    eye-candy.
    I'd like to hear what you really lost, or if this is just ludditity image
    Among other things, the hierarchical schematics (I know that finally
    Eagle also got it, but OrCAD had it 30 years ago!).
    Then the repeat function, when you did something and then OrCAD
    remembered the sequence and repeated it. Very handy when you need to do
    repetitive tasks, like putting a bunch of decoupling caps down. Draw
    one cap, set its value, adjust the position of its designator and value
    labels, draw the ground, the arrow to Vcc, move the pointer to the left
    by say 4 grid points, press end. Then every press of the repeat key
    will put down the next cap, valued, numbered, connected.
    Also, automatic label increment - when you needed to connect 32 data or
    address pins to the buses it took you to connect 1 pin then press the
    repeat key 31 times, done.
    The whole thing could be extended with OrCad asking you for input, I
    think they called that a 'macro'.
    Naming buses and OrCAD checking that members connecting to a bus indeed
    belong there was also quite cool.
    The fact that you didn't need to create a different component for every
    different power rail you have, because OrCAD had the concept of a
    power rail symbol. Symbols with matching values were connected.
    An other thing I really miss is the fact that you could move around on
    the grid by cursor keys, no need to constantly use the mouse. That was
    very, very covenient and made drawing things much faster than constantly
    switching between the keys and the rodent.
    There were other neat features too, but these are the ones that come to
    mind without much thinking, possibly because the lack of these
    frustrates me the most.
    Whether missing those features makes me a luddite, well, your call.
    Zoltán Kócsi
    eye-candy.
    Zoltán Kócsi
    Am 03.04.2017 um 21:33 schrieb warrenbrayshaw:
    On 3/04/2017 11:53 p.m., Hans Lederer wrote:
    But I could never before or after draw schematics so fast and easy as
    with OrCad SDT.............
    I still use something like that on Eagle, ............   But it needs many more keystrokes than OrCad did.
    Here is a link to the OrCAD SDT III Manual
    https://archive.org/details/OrCAD3Manual
    Ah, nice!  I'm sure I still have the printed book (dark green cover?)
    somewhere in my attic, together with it's d**d parport dongle.  Probably
    next to the “IBM PC 8088 Macro Assembler” binder…
    autodeskguest over 9 years ago in reply to rick_b
    On Sun, 02 Apr 2017 22:29:55 -0700, Rick Brown <ricksbmw@gmail.com>
    wrote:
    KiCad receives "some" funding from CERN, but most of the development is
    still done by volunteers when they can afford some free time from their
    life and real jobs. KiCad needs your donations to keep the pace of
    development up to users expectations. It is unlikely to ever keep up with
    Eagle until users start making meaningful contributions to KiCad. The cost
    of development by professional software engineers is about $60/hour. You
    can contribute here...
    https://giving.web.cern.ch/civicrm/contribute/transact?reset=1&id=6
    If you use it, contribute, especially if you make a living with it.
    Thanks for the reminder.  I made an anonymous 480 CHF (essentially
    $480) to the project when Eagle was murdered.  I just made a 120 CHF
    contribution and put an entry in my phone calendar to remind me to do
    that monthly.
    I challenge anyone who is pissed at what has been done to Eagle to do
    the same.
    John DeArmond
    http://www.neon-john.com
    http://www.tnduction.com
    Tellico Plains, Occupied TN
    See website for email address
    ...DOS OrCad SDT had clever one-letter commands so you could keep one hand
    on the mouse to point and the other hand at the keyboard to tap these
    commands (no <Enter> necessary) — very fast!
    I don't remember the commands exactly, its 25 years ago, but for
    instance something like this —
    <point> (P)lace (W)ire (B)egin <point> (P)lace <point> (P)lace <point>
    (E)nd
    gave a net with two bends.
    It had a clever (R)epeat command with auto-offset and auto-increment for
    many commands.   Tapping R three times would for instance give three
    copies of the above net, properly offset and named.
    Or you could place one resistor and then hold down R and let the
    keyboard autorepeat (R)epeat that resistor fifteen times.  Great for
    buses etc.
    Of course design tools have added a lot of features since and I wouldn't
    want to go back to those DOS tools now............
    Enjoy
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Am 03.04.2017 um 12:21 schrieb Morten Leikvoll:
    eye-candy.
    For instance two things I vividly remember and miss:
    commands (no
    (E)nd
    buses etc.
    want to go back to those DOS tools now.  I also wouldn't want to use
    these red and blue adhesive tapes ever again (some rerouting on a
    finished board — AARGH!)
    with OrCad SDT.
    I still use something like that on Eagle, with five-layered custom
    function keys and text commands — much better than menus or those
    hieroglyphic buttons (it is just an idiotic idea to use the mouse
    alternating for precise pointing and selecting buttons or menus
    elsewhere).  But it needs many more keystrokes than OrCad did.
  • brijeshsondarva
    brijeshsondarva over 9 years ago
    Yes I have used both of this software EAGLE CAD as well as DipTrace for design so many circuits and lots of practice with both of this software both have some good features and some its limitation too, like Diptrace have facility to auto place that feature not more expensive in EagleCad but EagleCad have great library function almost parts and components available in eagle cad and some parts have not in diptrace but in diptrace have good and advanced tool to show your PCB in 3D view after designing that's may be plus point of diptrace, but Eagle Cad is absolutely Good. image
    eye-candy.
