EAGLE User Support (English) Changing fonts
  • Replies 24 replies
  • Subscribers 181 subscribers
  • Views 5176 views
Changing fonts
I need to select non-standart font for all text in the schematics, but
Eagle does not support it. So I have to export sheet to DXF and edit it
with Autocad. It`s working, but change font in Eagle would be very easier.
    autodeskguest over 9 years ago in reply to rachaelp +1
    Am 17.04.2016 um 11:46 schrieb rachaelp: Michael Farr wrote: Given that there are very powerful, standard, anti-aliased fonts built-n to all platforms that are very easy for a developer to use, the font…
    autodeskguest over 10 years ago in reply to autodeskguest
    There is no need for proportional fonts to make pdf's searchable, so
    this argument is void. I have seen raw scanned pdf's searchable.
    I'm not sure how this is done, but I would think its some kind of
    metadata. Maybe this link is useful:
    http://searchable-pdf.com/content.php?lang=en&c=61
    HI Morten,
    I'm sure that in general you are correct. However, as far as EAGLE's
    current implementation proportional fonts are the only ones that are
    searchable in a PDF.
    I agree that you shouldn't have to use a font because it's the only
    thing that make a PDF searchable.
    hth,
    Best Regards,
    Jorge Garcia
    Tilmann Reh wrote on Wed, 04 November 2015 02:59
    A nice looking built-in vector font is the only good solution
    Not really.  Simply allowing us to define our own font is another way,
    which I'd prefer.  Eagle can default to the existing font.
    Quote:
    It shouldn't be too much work to implement Hershey as fourth font.
    I'd actually rather they didn't.  Then we'll end up with something else
    that's not quite what we want in some instances, but with once again no way
    to address it.  Make the definition of all the characters soft with
    commands to define whatever vectors you want per character.  Then we can
    all get whatever fonts we like.
    For example, I use the Hershey fonts too, mostly.  I've made a few minor
    customizations to them, and would like to use them too.  These include
    adding the Ohm, micro, and other symbols at known character codes.  Of
    course the TEXT command would have to be expanded to allow arbitrary
    character codes to be specified.
    Writing a program that takes a font definition and generates the Eagle
    script to load that into Eagle would be trivial.  People would probably
    upload scripts for various fonts, so those that are happy with someone
    else's details don't have to do anything beyond run a canned script.
    Give me customizability over built-in features!  This way Eagle doesn't
    have to include any new font at all, and doesn't need a complicated
    interface to manage fonts.  This should actually  be easier on the
    developers.
  • mikefarr
    mikefarr over 9 years ago
    Given that there are very powerful, standard, anti-aliased fonts built-n to all platforms that are very easy for a developer to use, the font support and in general the readability and look of Eagle is surprisingly bad.   I'm looking at the same schematic in Eagle and one my friend did in ORCad.  Eagle looks like my 1984 MacPlus with bitmapped fonts.   The lines of my triangular op-amps are actually pixelated!
    Eagle just doesn't look professional.
  • rachaelp
    rachaelp over 9 years ago in reply to mikefarr
    Hi Michael,
    What OS are you running and which version of EAGLE? Which font are you using in the schematics? With some tweaking I have managed to get things looking okay, the biggest issue is you need to have the standard ugly vector font in the board or else when you have your boards made the silk screen will likely be a mess.
    If you are using OSX and have a Retina display there are also rendering quality issues there as EAGLE doesn't correctly deal with HiDPI displays on OSX yet either, although they have made some improvements in 7.5.2 and I believe they are still working on getting it fixed properly.
    Best Regards,
    Rachael
    pixelated!
    Hi Michael,
    in the current beta 7.5.4 the problems with the MAC verions with
    high resolution diplays should be fixed.
    Richard Hammerl
    pixelated!
    Hi Michael,
    Richard Hammerl
    pixelated!
    Hi Michael,
    Richard Hammerl
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    Hi Richard,
    If the Mac HiDPI resolution issues are fixed this is a big deal for me so will be very happy! Looking on the website I can only see the 7.5.3 beta available. Do you know when 7.5.4 will be available?
    Many thanks,
    Rachael
    Am 22.04.2016 um 11:39 schrieb rachaelp:
    Hi Richard,
    Many thanks,
    Rachael
    https://www.element14.com/community/message/195269
    Ahh, sorry. I wrote "the current 7.5.4".... It should be released
    next week.
    Richard Hammerl
    Hi Richard,
    Many thanks,
    Rachael
    next week.
    Richard Hammerl
