EAGLE User Support (English) Re: Change tolerance of drill hole in Eagle 7.7.0
  • Subscribers 187 subscribers
  • Views 223 views
On 03-04-17 22:21, Joseph Katz wrote:
This seems like an incredibly basic question but I've spent an
embarrassing amount of time searching and not found the answer.
How do I change the tolerance of a drill hole?
It is defaulting to 0.0% and I'm getting an error saying that
drills are missing when I try to generate the excellon file,
which it looks like is because it doesn't quite match any
standard drills.
https://www.element14.com/community/message/220002
Hi Joseph
In the CAMprocessor you will find 2 text boxes under Tolerance
that you can set to a value, to have all possible diameters in
your board redirected to the Drill diameters available in the
machine you are using.
Autodesk
Andre Schmeets
